Hybrid In-Ear Monitors IEM Planar Magnetic + Balanced Armature 16Ω 100dB 5Hz-40kHz
The Dunu Talos in-ear monitors are a hybrid model featuring both a 14.6mm Planar Magnetic driver and two custom Balanced Armature drivers embedded in an innovative architecture. They are equipped with a switch that allows you to switch between Planar and Hybrid Planar modes for a unique sound experience. In Planar mode, the Talos provide a smooth, natural and warm sound for long listening sessions. The Hybrid setting, on the other hand, promotes a transparent, accurate and detailed sound.
The Dunu Talos are equipped with a brand new Planar Magnetic driver with an ultra-thin 14.6mm diaphragm. It uses an extremely light silver alloy coil and a double-sided N55 magnetic circuit. It is tuned to perfectly reproduce the entire frequency range, with very low distortion and fast transients.
Talos also features two specially tuned and optimized Balanced Armature drivers. These are particularly comfortable in the reproduction of high and ultra-high frequencies, ensuring a transparent response and great clarity for enjoying music in all its details.
The body of the Dunu Talos is ergonomically shaped, precision-machined from aluminum alloy using CNC (computer numerical control) for optimum wearing comfort. Each earpiece incorporates gold-plated brass acoustic cavities to ensure natural sound. Multiple vents on the earphone shell form a unique airflow microcontrol system to ensure dynamic sound and deep bass.
The Dunu Talos come with a detachable cable with silver-plated single crystal copper conductors, providing excellent conductivity for perfect signal transmission. The cable connects to the headphones via standard 2-pin CIEM 0.78mm connectors.
Product type | In-ear monitors |
Impedance | 16Ω |
Sensitivity | 100dB ±1dB @ 1kHz |
Frequency response | 5Hz - 40kHz |
Drivers | 1* Planar Magnetic 14.6mm 2* Balanced Armature |
Operating modes | Planar mode: switch position "I" Planar + BA hybrid mode: switch position "ON" |
Length of the cable | 1.2m |
Earphones connector | CIEM 0.78mm |
Cable conductors | Silver plated copper |
Connectors body material | Aluminum |
Weight | 14g |
Color | Black |
Impedance (Ω) | 16 |
Efficiency / Sensitivity (dB) | 100.0 |
Lowest frequency (Hz) | 5 |
Highest frequency (Hz) | 40000 |
