SHANLING SONO In-Ear Monitors IEM Dual Driver Dynamic + 1 BA 16Ω 103dB 16Hz-20kHz
Shanling's IEM SONO earphones offer excellent audio performance. With a frequency response of 16Hz to 20kHz and a sensitivity of 103dB, the listening experience is immersive, with deep, smooth bass, present midrange that brings out voices and instruments, and refined, controlled treble. This performance is made possible by a structure in which each driver is dedicated to a specific frequency.
Reference : 18024
79,00 €tax incl.
65,83 € tax excl.
Last items in stock !
Shipping date: 25-07-2025.
SHANLING SONO
SHANLING SONO Écouteurs Intra-Auriculaires IEM Double Driver Dynamique + 1 BA 16Ω 103dB 16Hz-20kHz
Shanling's IEM SONO earphones offer excellent audio performance. With a frequency response of 16Hz to 20kHz and a sensitivity of 103dB, the listening experience is immersive, with deep, smooth bass, present midrange that brings out voices and instruments, and refined, controlled treble. This performance is made possible by a structure in which each driver is dedicated to a specific frequency. The two dynamic drivers are respectively dedicated to bass and midrange, while the balanced armature driver is dedicated to treble.
A complex structure: 2DD + 1BA with triple magnet and HCCAW coil
The bass driver is a Ø9.2mm bio-diaphragm, while the midrange driver is a Ø6.8mm crystalline diaphragm. Three magnets are present in the earphone structure to enhance sensitivity and precision in the bass and midrange. The HCCAW coil provides more expressive and detailed sound reproduction. The BA driver dedicated to high frequencies extends and softens them without unwanted peak.
Filter tips for different listening experiences
The filter tip with its black ring delivers a balanced, warm sound with barely pushed bass. The red-ringed filter tip, on the other hand, delivers a much stronger bass, with a more powerful kick and extended deep bass.
A robust shell
The metal body of Shanling's SONO in-ear earphones makes them as durable as they are visually pleasing. The body is made from a zinc alloy casting with CNC-engraved details, and is hand-polished.
HiFi quality cable
The interchangeable cable supplied with SONO headphones is made of 4 braids, each with 32 single-crystal copper strands, and is silver-plated. The male 3.5mm Jack plug is gold-plated, and the earphones feature standard 2-pin 0.78mm connectors.
Product typeIn-ear monitors (IEM)
Speaker type2 dynamic drivers + 1 balanced armature driver
Frequency response16Hz-20kHz
Impedance16Ω
Sensitivity103dB
Body materialZinc alloy
Cable connectors1x 3.5mm jack
2x 0.78mm 2pins CIEM
Cable conductor4x 32 monocristallin silver-plated copper wire
Cable lenght1.3m
ColorSilver and transparent
Weight8.6g per earphone
Package1x Shanling SONO in-ear monitors (IEM)
1x 3.5mm jack to 2pins 0.78mm cable
4x Pair of ear-tips
2x Filter tips
1x Storage pouch
ColorTransparent
ColorSilver
Impedance (Ω)16
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)16
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
Shanling's IEM SONO earphones offer excellent audio performance. With a frequency response of 16Hz to 20kHz and a...
