THIEAUDIO PRESTIGE LTD In-Ear Monitors IEM Dynamic Electrostatic 22 Ohm 98dB 20Hz-80kHz
With these Prestige LTD in-ear earphones, Thieaudio unveils an innovative, high-end pair of earphones that follows on from the Prestige Original model. Indeed, the Prestige LTD also benefit from a hybrid design with no less than 9 drivers in each earphone; 4 Sonion electrostatic tweeters for high frequencies, 4 Knowles and Sonion Balanced Armature drivers for mids and a 10mm dynamic driver for bass. The result is a sound reproduction that is transparent, precise and rich in detail.
By buying this product you get 139 loyalty points
Reference : 18117
1 399,00 €tax incl.
1 165,83 € tax excl.
Shipping date: 13-08-2025.
THIEAUDIO PRESTIGE LTD Écouteurs Intra-Auriculaires IEM Dynamique Électrostatique 22 Ohm 98dB 20Hz-80kHz
With these Prestige LTD in-ear earphones, Thieaudio unveils an innovative, high-end pair of earphones that follows on from the Prestige Original model. Indeed, the Prestige LTD also benefit from a hybrid design with no less than 9 drivers in each earphone; 4 Sonion electrostatic tweeters for high frequencies, 4 Knowles and Sonion Balanced Armature drivers for mids and a 10mm dynamic driver for bass. The result is a sound reproduction that is transparent, precise and rich in detail. To make this complex assembly work, the Prestiges LTD incorporate a 5-way crossover (passive crossover network) which distributes the different frequencies to the drivers, resulting in an extremely textured, wide-band soundstage.
The innovation in this model from Thieaudio's Prestige range lies in the fact that high-frequency peaks that can deteriorate the listening experience have been eliminated, making it one of the best pairs of IEM earphones using electrostatic driver technology (EST) on the market today. In addition, the overall sound signature is more balanced and bass tighter thanks to modifications made to the 10mm dynamic driver.
A rich, balanced sound signature
The tone of the Prestige LTD is quite different from that of the original model in the range. Modifications to the 10mm dynamic driver have tightened the bass at 200Hz, bringing greater responsiveness, dynamism and precision for a cleaner, more transparent sound. The midrange, meanwhile, is sharper than ever, in line with the standards of professional studio monitors. As for the treble, it boasts the same extension capacity as the Prestige Original, but this time with the elimination of unwanted peaks for a more pleasant listening experience. Improved use of electrostatic drivers (EST) has resulted in a more natural treble curve.
High-quality cable and connectors
The litz wire cable supplied with Prestige LTD earphones is a 22AWG cable made of silver-plated and silver graphene-plated 6N OCC pure copper conductors. This graphene coating provides enhanced resistance to oxidation and corrosion, as well as protection against electromagnetic interference. Moreover, the cable incorporates a modular system enabling the user to connect the various terminations supplied (4.4mm and 2.5mm balanced jack or 3.5mm unbalanced jack). CIEM 0.78mm connectors have also been enhanced to strengthen the link with earphones.
Ergonomic, comfortable design
The Prestige LTD shell is directly inspired by the brand's V16 Divinity model, whose comfort during long listening sessions has been fully demonstrated. The shell material is made from 3D-printed medical resin, a durable and perfectly hypoallergenic material. In terms of aesthetics, they are inspired by the Milky Way, an inspiration that announces a listening experience that brings out the best in your musical universe.
Product typeIn-ear monitors (IEM)
Drivers4x Electrostatic driver (EST)
4x Balanced Armature driver
1x Dynamic driver
Impedance22Ω
Sensitivity98dB
Frequency response20hZ-80kHz
Conductors cable material OCC 6N Copper
Conductors cable platingSilver and graphene silver
Cable lenght1.2m
Conductors cable section0.326mm² (22AWG)
IEM connectorsCIEM 0.78mm
Package1x Thieaudio Prestige LTD in-ear monitors
1x 1.2m cable with 0.78mm CIEM connectors and modular termination
1x 4.4mm balanced jack connector
1x 2.5mm balanced jack connector
1x 3.5mm unbalanced jack connector
1x Carrying case
Impedance (Ω)22
Efficiency / Sensitivity (dB)98.0
Lowest frequency (Hz)20
Highest frequency (Hz)80000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 2.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
Fin du jeu
Simplement les meilleurs iem que j'ai entendu! Contrôle qualité au top les 2 unités sonne parfaitement. Un monstre de technique, de details, de fluidité, de séparation d'instruments, une scènes sonore énorme, le son est hors de la tête dans toutes des directions! Mention S+ pour audiophonics.fr pour la rapidité d'envoi, commandé la veille et reçu le lendemain le tout très bien emballé.
This review has been posted for THIEAUDIO PRESTIGE LTD In-Ear Monitors IEM Dynamic Electrostatic 22 Ohm 98dB 20Hz-80kHz
With these Prestige LTD in-ear earphones, Thieaudio unveils an innovative, high-end pair of earphones that follows on...
