3E AUDIO A5SE Amplifier
3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A5se amplifier is based on one TI TPA3251 chip in BTL configuration, and two dual NE5532 OPAs. This means it can deliver up to 2x140W into 4 ohm.
Reference : 20380
219,00 €tax incl.
182,50 € tax excl.
Shipping date: 25-07-2025.
3E Audio A5seClass D Stereo Amplifier BTL 1xTPA3251 2x140W 4 ohm
Photo of 3E Audio A5se
In terms of connectors, the 3E Audio A5se features an RCA input, a convenient balanced XLR/Jack 6.35mm combo input, and an output on speaker terminals. The RCA input gain can be adjusted (LOW=23dB, HIGH=26dB), and the preamplifier stage and volume control can be bypassed for use as a power amplifier. Versatile and high-performance, this little amplifier is able to offer a good reserve of power while preserving the final sound reproduction.
A7
A7se
A7 Mono
A5se
A5
Amplification chip
2x TPA3255
2ch - PBTL
1x TPA3255
2ch - BTL
1x TPA3255
1ch - PBTL
1x TPA3251
2ch - BTL
2x TPA3251
2ch - PBTL
Output power
(4 ohm, THD+N=1%)
2x 250W
2x 230W
1x 260W
2x 140W
2x 150W
Output power
(8 ohm, THD+N=1%)
2x 140W
2x 130
1x 150
2x 70W
2x 80W
Load impedance
2-16 ohm
4-16 ohm
2-16 ohm
4-16 ohm
2-16 ohm
3E Audio A5se: One TPA3251 chip
The TPA3251 amplifier chip offer a consistent level of output power, as the 3E Audio A5se delivers up to 2x140W under 4 ohm and up to 2x70W under 8 ohm (THD+N = 1%).
TPA3255 chips
Interchangeable DIP8 OPAs
3E Audio A5se: Interchangeable OPAs
The preamplifier stage of the 3E Audio A5se is made up of two double NE5532 OPAs mounted in DIP 8 and easily replaceable with pliers, thanks to the design of the case. In fact, the OPAs can be accessed through two hatches without opening the case. Here's a non-exhaustive list of compatible OPAs: OPA1656, OPA1602, OPA2134, NE5532P, LME49720, LM4562, MUSES02, MUSES8920, NJM4580, NJM4556, NJM2068, OP249, AD827, etc.
Please take care not to damage the device or the OPAs when replacing or handling them. Any damage to the device caused by improper handling by the user (reverse mounting of OPAs, mounting of non-compatible OPAs, etc.) will invalidate the product warranty. Please refer to the manual to carry out the operation.
3E Audio A5se: Quality components
Rubycon 63V 1000uF capacitors
Rubycon capacitors meet high current requirements, reducing noise and improving THD.
Flat wire coils
Flat-wire coils
The coils used in the amplifier provide improved linearity and reduced distortion, while delivering the best performance whatever the load.
TDK capacitors
TDK capacitors
These highly reliable LC filter capacitors ensure optimum audio performance.
3E AUDIO A5se amplifier PCB photo
3E Audio A5se overview
Overview of the 3E Audio A5se
1Left channel status LED
2RCA input status LED
3Multifunction button
4XLR input status LED
5Right channel status LED
6Balanced XLR/Jack 6.35mm combo input
7RCA input
8RCA gain control
9Speaker terminal output
10Volulme bypass
1136V-38V DC power supply via DC jack
Product typeClass D amplifier
ChannelsStereo
Amplification chip1x TI TPA3251
OPADual OPA NE5532
ArchitecturePFFB
Inputs1x Single-ended RCA input
1x Balanced XLR/jack 6.35mm combo input
Output1x Speaker terminal output
Input impedanceRCA : 10kΩ
XLR/TRS : 20kΩ
Volume attenuation-50dB
Volume bypass
RCA gain control
Audio specifications (RCA IN)
THD+N (5W)0.0004% @ 4Ω
0.0005% @ 8Ω
SNR (1% THD+N, 1KHz, A-wt)121dB
Dynamic range (1% THD+N, 1KHz, A-wt)121dB
Frequency response (±0.5dB)20Hz-30KHz
Noise (A-wt)< 13uVrms
Crosstalk-100dB
Gain23dB / 26dB
Input sensitivity1.75Vrms
Output power (1% THD+N)2x 140W @ 4Ω
2x 70W @ 8Ω
Output power (10% THD+N)2x 170W @ 4Ω
2x 90W @ 8Ω
Output impedance2Ω-16Ω
audio specifications (XLR IN)
0.0003% @ 8Ω
SNR (1% THD+N 1KHz A-wt)123dB
Dynamic range (1% THD+N 1KHz A-wt)123dB
Crosstalk-100dB
Gain17dB
Input sensitivity3.5Vrms
2x 700W @ 8Ω
2x 90W @ 8Ω
Output impedance4Ω-16Ω
Supply voltage36V-38V DC 5A (The supplied power supply operates on 110V and 230V)
Power consumptionOFF: < 0.2W
ON (no audio) : 6W
Dimensions170 x 168 x 46mm
Weight1000g
Package1x 3E Audio A5se amplifier
1x 38V 5A power adapter
InputXLR
InputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3251
Power (W)140.0
3E AUDIO A5SE Class D Stereo Amplifier BTL 1xTPA3251 2x140W 4 Ohm
3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A5se amplifier...
