The iEast Audiocast AMP50 is a connected amplifier that combines the functions of amplifier and streamer. It can deliver up to 2x 50W under 4 ohm thanks to a ACM3129A amplification chip, and can connect to the network via Wi-Fi or its ethernet RJ45 port. Bluetooth 5.0 functionality is also available for fast, stable wireless transmission. The AMP50 can be controlled via the Audiocast APP Control, which features a wide range of settings. Multiroom operates in stand-alone or partition mode for greater flexibility. Connectivity is more than essential, with various digital inputs, a 3.5mm analog AUX input and a Phoenix terminal output. Numerous accessories are supplied for direct use of the AMP50.
The AMP50, as its name suggests, delivers up to 50W per channel at 4 ohms load. At 8 ohms, it can deliver up to 2x25W. Output is via a screw terminal block, and a screw terminal to banana plug adapter is supplied.
This AMP50 amplifier/network player features a 2.4GHz Wi-Fi connection for a fast, stable connection. This makes it easy to access your audio files, whether stored on a smartphone, computer or NAS. It supports AirPlay and DLNA/UPnP protocols.
Combined with other Audiocast products, the AMP50 can be used to set up a multi-room system with two operating modes:
The AMP50 features a Bluetooth 5.0 receiver chip supporting the SBC codec for stable, reliable wireless transmission of your music via a smartphone, for example.
The Audiocast control app gives you access to all your streaming services, such as Spotify, Tidal, Deezer, YouTube Music and Apple Music, as well as to numerous Internet radio stations. The application also offers a wide range of settings, including bass and treble equalization for personalized listening.
1 | Stereo output on screw terminal block |
2 | Stereo AUX input on 3.5mm jack |
3 | USB-A input |
4 | Ethernet RJ45 port |
5 | 12-24V DC jack power input |
6 | Toslink optical input |
7 | Pairing button |
Product type | Amplifier / Network player |
Inputs | 1x USB-A input 1x 3.5mm jack 1x Toslink optical input WiFi Bluetooth |
Output | Speaker terminals (Phoenix) |
Output power | 2x50W @ 4 ohm (THD=1%) 2x25W @ 8 ohm (THD=1%) |
Input sensitivity | 70mW @ (full power) |
SNR | < 0.1% |
WiFi | WiFi IEE802.11 b/g/n 2.4GHz |
Bluetooth | Bluetooth 5.0 |
Supported Bluetooth codecs | SBC |
Supported audio formats | APE, FLAC, MP3, WAV, AAC, AAC+, WMA, ALAC, AIFF |
Supported transmission protocols | DLNA, AirPlay, Spotify Connect, QPlay |
Supported sample rate | Up to PCM 24bit 192kHz |
Ethernet | 10/100M |
Smart Home control | TCP/IP |
Power supply | 20V/3A DC |
Dimensions | 136 x 134.8 x 40.1mm |
Package | 1x iEast Audiocast AMP50 1x Adapter from screw speaker terminals to banana plug sockets 1x 3.5mm jack to RCA stereo cable 1x 3.5mm jack to 3.5mm stereo jack cable 1x AC adapter and power cable |
Input | USB |
Input | Optical |
Input | WiFi |
Input | Jack 3.5mm |
Input | Bluetooth |
Output | Phoenix connector |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 50.0 |
Remote Control | Yes |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Qobuz |
