NAD M10 V2 Amplifier nCore Streamer BluOS WiFi Bluetooth ES9028 2x100W 4 Ohm
Succeeding the excellent multi-awarded NAD M10 connected amplifier, the M10 V2 takes its technical base while bringing several improvements and features. We therefore find a streamer and amplifier particularly powerful and versatile, with extended connectivity thanks to WiFi and bidirectional Bluetooth, but also with a wide range of connectors including subwoofer outputs and an eARC HDMI port.
By buying this product you get 247 loyalty points
Reference : 17303
2 475,00 €tax incl.
2 062,50 € tax excl.
NAD M10 V2
Streamer BluOS Amplifier nCore WiFi Bluetooth ES9028 2x100W 4 Ohm
NAD M10 V2 Lecteur réseau BluOS Amplificateur nCore WiFi Bluetooth DSP 2x100W 4Ω
nCore Amplifier & Dirac Live DSP
The amplifier stage of the NAD M10 V2 embeds an nCore HybridDigtal module, capable of delivering a power of 2x100W under 4 and 8Ω with a high efficiency. A power that allows it to be integrated even within demanding audio systems, but also a controlled power for a precise, dynamic and incredibly lively sound reproduction.
In addition, the M10 V2 includes a Dirac Live Room DSP for effective acoustic correction to optimize the sound of the device for the speakers and your listening room. The use of a calibration microphone (not supplied) allows to establish an optimized profile in an automatic and easy way.
Sabre ESS ES9028 DAC
The digital-to-analog conversion section uses a Sabre ESS ES9028 chip, capable of high quality decoding for clear and detailed sound reproduction. It also supports high-resolution audio streams up to PCM 32bit 384kHz.
BluOS & Mobile app
The NAD M10 V2 is powered by an ARM Cortex A9 1GHz processor and the BluOS operating system. The latter, through an ergonomic and attractive interface, ensures an intuitive use. It allows you to access your music and set up your device easily and quickly.
The M10 V2 is also remotely controllable with the free BluOS Controller mobile app available on Android and iOS. It allows you to manage your music playback, access your network storage and even offers the possibility of multi-room management, BlueSound compatible.
Full control
The NAD M10 V2 is also controllable with the voice assistants Amazon Alexa and Apple Siri. You just need to have a smart system (not included) of this type to take control of your music by voice.
An extended connectivity
The rear panel of the NAD M10 V2 reveals a complete connectivity, allowing it to be integrated into most audio systems. It offers stereo RCA, coaxial, optical, USB-A (USB Host for storage devices), an Ethernet RJ45 port and an HDMI eARC input. For the outputs, the M10 V2 offers HP terminals but also a pre-out on stereo RCA as well as two subwoofers outputs.
112V Trigger input
212V Trigger output
3Stereo RCA input
4Stereo RCA input
5Stereo RCA pre-out
6Subwoofer outputs
7Coaxial input
8Optical Toslink input
9HDMI eARC input
10USB-A input (USB Host)
11Ethernet RJ45 input
12Service port
13Standby button
14Power connector
15Right channel speaker output
16Left channel speaker output
Design
The robust chassis of the M10 V2 features a large and beautiful color touchscreen on the front, which is automatically activated by a proximity sensor when the hand is approached. This, in combination with the BluOS software interface, allows a fluid and intuitive navigation for an optimal user experience.
Product typeStreamer
Amplifier
InputsBluetooth
WiFi
2* Stereo RCA
1* Coaxial
1* Optical Toslink
1* HDMI ARC
1* USB-A (USB Host)
1* Ethernet RJ45
OutputsBluetooth
WiFi
1* Stereo RCA pre-out
2* RCA subwoofer outputs
Speaker terminals
ConnectivityWiFi 5
Two-way Bluetooth
Ethernet Gigabit RJ45
Other connectors12V Trigger in/out
DAC chipESS Sabre ES9028
OSBluOS
Supported audio formatsMP3, AAC, WMA, OGG, WMA-L, ALAC, OPUS
Supported high resolution audio formatsMQA, FLAC, WAV, AIFF, DSD
Supported sampling ratesPCM up to 32bit 192kHz
Supoprted straming services and webradiosSpotify
Deezer
Qobuz
Tidal
Amazon Music
Napster
HDTracks
HighResAudio
Murfie
Juke
Slacker Radio
KKBox
Bugs
TuneIn Radio
iHeartRadio
Calm Radio
Radio Paradise
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD
Dolby Digital compatibilityUp to 4.2 channels
Output power> 100W (ref. 20Hz-20kHz @ rated THD, two channels)
THD< 0.03% (250mW to 100W, 8Ω and 4Ω)
SNR> 85.1dB (A-Weighted, 500mV input, ref. output 1W @ 8Ω)
Clipping power> 130W à 1kHz, 8Ω, 0.1% THD
> 230W @ 1kHz, 4Ω, 0.1% THD)
IHF Dynamic power8Ω: 160W
4Ω: 300W
Damping factor> 190 (ref. 8Ω, 20Hz-20kHz)
Frequency response±0.6dB (20Hz-20kHz)
Tone controlTreble: ±6.0dB @ 20kHz
Bass: ±6.0dB @ 60Hz
Channel separation> 83dB (1kHz)
70.5dB (10kHz)
Input sensitivity (@ 100W, 8Ω)Line in: 456mV
Digital in: -13.23%Fs
Supply voltage100-240VAC 50/60Hz
Dimensions (L*P*H)245*260*100mm
InputRJ45
InputWiFi
InputHDMI
OutputSubwoofer
OutputWiFi
OutputSpeaker terminal
OutputBluetooth
DAC / ADC ChipES9028Q2M
Max sampling rate192kHz
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)100.0
Remote ControlYes
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Succeeding the excellent multi-awarded NAD M10 connected amplifier, the M10 V2 takes its technical base while bringing several improvements and...
