O-NOORUS D1 Class D Amplifier TPA3255 PFFB
The O-Noorus D1 amplifier is based on a PFFB (Post Filter FeedBack) architecture and a TPA3255 amplifier chip coupled to two NE5532 AOPs, enabling it to deliver up to 2x 250W @ 4ohm (1% THD+N, with a 50V power supply).
Reference : 19226
115,00 €tax incl.
95,83 € tax excl.
O-NOORUS D1 Class D Amplifier TPA3255 PFFB 2x250W 4 Ohm Red
O-Noorus D1 picture
The O-Noorus D1 amplifier is based on a PFFB (Post Filter FeedBack) architecture and a TPA3255 amplifier chip coupled to two NE5532 OPAs, enabling it to deliver up to 2x 250W @ 4ohm (1% THD+N, with a 50V power supply). In terms of connectivity, the D1 has the essentials, with an analog RCA input and a speaker output, plus a subwoofer output for a 2.1-channel system, and a 3.5mm jack pre-out. The cutoff frequency of the subwoofer output is 80Hz for deep, immersive bass.
This O-Noorus amplifier operates in two distinct modes: BP (ByPass) and T&B (Treble & Bass). ByPass mode, as its name suggests, does not allow volume control, so the amplifier will operate at full power, while T&B mode allows volume control and treble and bass adjustment over a range of -/+10db thanks to an NJW1194 volume control chip. An infrared remote control completes the package for an optimal user experience.
Les composants du O-Noorus D1
O-NOORUS D1: output for active subwoofer
The D1 incorporates a subwoofer output for setting up a 2.1-channel system and enjoying a small home cinema set-up or simply listening to music with immersive bass.
Photo de la sortie Subwoofer du O-Noorus D1
Contrôle du potentiomètre du O-Noorus D1
O-NOORUS D1: control via potentiometer or IR remote control
The potentiometer not only controls the volume, but also changes the operating mode of the D1 amplifier. An IR remote control provides easy access to the many settings available, including operating mode, volume, treble, bass, screen color and brightness.
O-Noorus D1 remote control
O-Noorus D1 overview
1Menu
2LED operating mode indicator
3Submenu display (volume, treble, bass, etc.)
4Mute LED indicator
5IR remote control receiver
6Multifunction knob/potentiometer
7Right channel RCA input
8Left channel RCA input
9Subwoofer output
10Pre-out jack 3.5mm
11Speaker terminal output
1224V-50V DC power supply input
Product typeAmplifier
Amplification typeClass D
Amplification chipTI TPA3255
OPA2x NE5532
Input1x Stereo RCA
OutputsSpeaker terminals
1x Subwoofer
1x Pre-out jack 3.5mm
Output power2x 250W @ 4 ohm (1% THD+N, with 50V power supply)
THD≤ 0.01%
SNR≥ 109dB
Terminaison impedance2-8Ω
Frequency response20Hz-20kHz
Remote control operating distance25m
Power supply24V-50V DC (36V/5A power supply included)
Dimensions120 x 170 x 38mm
Weight0.650kg
ColorRed
Package1x O-Noorus D1 amplifier
1x Remote control
1x Power supply DC 36V/5A
OutputSubwoofer
OutputJack 3.5mm
OutputSpeaker terminal
ColorRed
Channel2.1
Amplifier chipTPA3255
Power (W)250.0
Remote ControlYes
The O-Noorus D1 amplifier is based on a PFFB (Post Filter FeedBack) architecture and a TPA3255 amplifier chip coupled to two NE5532 AOPs, enabling...
