Connector
Max sampling rate
DAC / ADC Chip
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Input
Output
Remote Control
Networking
Color
Zacharias L.
Very good but...
Pavol B.
Pavol B.
Moderate plugs
These RCA plugs looks good, quality made, aluminum body, good plast /no melting/, easy work with them. Pins and etc look...
Jack Adapters
We offer you a very wide range of Jack adapters, in fact these can be declined in a very large number of references. Stereo or mono jack adapters, gold-plated or unplated, male or female. You will also find DC jack adapters to screw terminals for power supplies. A wide range of applications and uses are covered with our jack adapters.
