DAYTON AUDIO ND140-4 Speaker Driver Midbass Aluminium 40W 4 Ohm 88dB 54Hz - 8000Hz Ø13cm
The ND140-4 is a midrange bass type amplifier belonging to the NEO series from Dayton Audio. Modern and resistant, it uses an aluminum cone rimmed with rubber to maintain a good sound.
Reference : 12633
43,90 €tax incl.
36,58 € tax excl.
Shipping date: 02-09-2025.
Grantie 5 ans
ND140-4 Medium / Serious Neo Balance Series Speaker by Dayton Audio
Speaker Dayton Audio ND140-4
The ND140-4 is a midrange bass type speaker belonging to the NEO series from Dayton Audio. Modern and resistant, it uses an aluminum cone rimmed with rubber to maintain a good sound. Its magnet is Neodynium, a high-performance material that also allows it to access the Neo range self-armoring features. The ND140-4 is therefore self protected against interference from the most common electromagnetic sources (TV, HDD, telephone) which are likely to damage the materials or to parasitize the signal.
ND140-4 - a natural and dynamic restitution for a pleasant listening
Midbass Speaker Dayton Audio ND140-4
This HP benefits from a nice balance between diameter and extrusion. The ND140-4 produces nice and deep bass frequencies with a low midrange. The quality of low frequencies is surprising, especially for a speaker of this format. The ND140-4 is therefore a choice piece to replace / repair / upgrade an existing speaker. in this respect, its relatively conventional format allows it to easily install in many models without involving drilling or DIY beyond the simple stroke of screwdriver.
Speaker TypeMid Bass
PowerRMS : 40 Watts
Max : 80 Watts
Impedance4 Ohms
Dimensions138 x 70,5 mm
Frequency Response54 Hz – 8kHz
Sensitivity88,4 dB 2,83V/1m
Voice Coil Diameter25,4 mm
Resonance Frequency59,2 Hz
Nominal Diameter133,35 mm
DC Resistance (Re)3,7 Ohms
Voice Coil Inductance (Le)0.79 mH @ 1 kHz
Electromagnetic Q (Qes)0.72
Mechanical Q (Qms)5.35
Total Q (Qts)0.63
Diaphragm Mass (including Airload) (Mms)10.1g
Mechanical Compliance of Suspension0.71 mm/N
Surface Area of Cone86.6 cm²
Maximum Linear Excursion4.0 mm
Speaker Power (W RMS)40.0
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (mm)130.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)81.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)54
Highest frequency (Hz)8000
Download
DAYTON_AUDIO_ND140-4_SPECS
Specifications and technical sheet for ND140-4
Download (231.17k)
3 reviews
haut parleur de 133cm avec une très belle restitution de grave et des voix amples. Le cône est d'une bonne résistance et le montage est facilité par la largeur des trous. Associé idéalement à un petit tweeter le Dayton ND140-4 devrait donner des résultat impressionnant dans tout type de projet
This review has been posted for DAYTON AUDIO ND140-4 Speaker Driver Midbass Aluminium 40W 4 Ohm 88dB 54Hz - 8000Hz Ø13cm
Great product
Great product just what I needed.
Bon petit HP
J'ai acheté ces HP's pour réaliser une paire d'enceintes 2 voies compactes à un prix raisonnable.
Le HP est de bonne facture, donne de bonne basses pour un HP de ce diamètre, ils encaissent bien a puissance !
Je recommande ce HP fortement !
Fred.
The ND140-4 is a midrange bass type amplifier belonging to the NEO series from Dayton Audio. Modern and resistant, it uses an aluminum cone rimmed...
