MONACOR SPH-100C Speaker Driver Midbass 30W 8 Ohm 84dB Ø 10cm
Monacor SPH-100C
Reference : 827
49,90 €tax incl.
41,58 € tax excl.
Available
Shipping date: 12-12-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
50 W MAX , 8 Ω Hi-Fi Mid-Bass Loudspeaker
This carbon diaphragm loudspeaker provides a high level of bass for its diameter. It will be suitable for the design of small volume speakers of high quality.
src = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" />
Impedance (Z) 8 Ω
Resonance frequency (fs) 50 Hz
Maximum bandwidth f3-6000 Hz
Freq. cut. (fmax). 2000 Hz
Maximum power 50 W MAX
Rated power (P) 30 W RMS
Pressure sound. (1W / 1m) 84 dB
Compliance susp. (Cms) 1.45 mm / N
Moving mass (Mms) 7 g
Mechanical resistance (Rms) 0.6 kg / s
Mechanical overvoltage. (Qms) 3.53
Electrical overvoltage (Qes) 0.50
Fact. total surge (Qts) 0.44
Volume equ. (VAS) 6 l
DC resistance. (Re) 6 Ω
Inductance coil. (The) 0, 65 mH
Coil diameter 25.5 mm
Coil holder Kapton
Height winding 14 mm
Air gap height 6 mm
Linear Excursion (X MAX ) ± 4 mm
Transmitting surface (Sd) 54 cm 2
Flight. air displaced (Vd) 21.6 cm 3
Force factor (BxL) 5.1 Tm
Ref. (No) 0.1%
Magnet diameter 90 mm
Magnet Weight 10.7 oz.
cutting Ø 98 mm
Mounting Depth 50 mm
Dimensions 106 x 106 mm
Weight 0.85 kg
Recommended Min Volume
<img src = "http://www.monacor.com/global_img/blank.gif" alt = "" width = "10" height = "1" />
closed 2.5 l
bass reflex 6 l
[Img-20592-left-thickbox_default]
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (cm)100
Diaphragm typeCarbon kevlar
Efficiency (dB)84
Xmax (mm)4
Highest frequency6000
Colissimo - TNT - SoColissimo
