DYNAVOX X7000 Power Filter 6 Schuko Sockets Black
The Dynavox X7000, a direct evolution of the X6000, is a HiFi mains filter that provides your audio devices with a clean and stable power supply for quality sound reproduction. It filters out harmful interference from your power supply to cancel out residual noise.
Reference : 14487
175,00 €tax incl.
145,83 € tax excl.
Shipping date: 03-06-2025.
Dynavox X7000
Dynavox X7000 Filtre Secteur 6 Prises Schuko Noir
The Dynavox X7000, a direct evolution of the X6000, is a HiFi mains filter that provides your audio devices with a clean and stable power supply for quality sound reproduction. It filters out harmful interference from your power supply to cancel out residual noise. The X7000 is equipped with 4 filtered and 2 unfiltered Schuko plugs. Its front panel has a display indicating the input voltage or power consumption. This display can also be switched off if necessary and in order to limit light pollution. The X7000 also benefits from a memory allowing it to remember the last parameters used (voltage and ON/OFF display). Installation is very simple and all components are integrated in a robust aluminium housing. In addition, to protect your system, it includes a 10A circuit breaker as well as an LED that can indicate a phase inversion on the power supply line.
Product typePower strip
Main filter
Connectors4x Filtered female Schuko
2x Unfiltered female Schuko
Input voltage220-240V 50Hz
Circuit breaker10A
Output power2300W (230V)
Dimensions430 x 305 x 100mm
Housing materialAluminium
Weight6.15kg
Number of sockets6
FilteringYes
3 reviews
j'ais oublié les étoiles
This review has been posted for DYNAVOX X7000 Power Filter 6 Schuko Sockets Black
une tuerie
Au départ , j'étais assez sceptique comme tout le monde
mais maintenant , c'est le jour après la nuit .
Plus de ronronnement ,de bourdonnement même les sifflements ont disparus .
Faut dire que je l'associe avec trois câbles secteur digne de ce nom .
De la musique rien que de la musique ,pour tout vous dire , je suis possesseur d'un ampli ADVANCE PARIS A10 CLASSIC que je redécouvre .
Je ne pouvais pas l'utiliser en classe A , c'était trop diffus ,trop brouillon .
Aujourd'hui que du bonheur musical .
De plus si je peux me permettre , la configuration interne ressemble étrangement à une autre marque plus chère ,
le TAGA HARMONY PF-2000 ;
Je ne suis pas spécialiste en la matière mais à deux babioles prés , on n'est pas loin .
Moi , j'ai franchi le pas et pas de retour en arrière .
Filtre secteur
Mes appareils sont enfin protégés le wattmètre est très pratique pour connaitre la consommation réel de chaque appareil , merci top
The Dynavox X7000, a direct evolution of the X6000, is a HiFi mains filter that provides your audio devices with a clean and stable power supply...
