Power Filter 6 Schuko Sockets Black
The Dynavox X7000, a direct evolution of the X6000, is a HiFi mains filter that provides your audio devices with a clean and stable power supply for quality sound reproduction. It filters out harmful interference from your power supply to cancel out residual noise. The X7000 is equipped with 4 filtered and 2 unfiltered Schuko plugs. Its front panel has a display indicating the input voltage or power consumption. This display can also be switched off if necessary and in order to limit light pollution. The X7000 also benefits from a memory allowing it to remember the last parameters used (voltage and ON/OFF display). Installation is very simple and all components are integrated in a robust aluminium housing. In addition, to protect your system, it includes a 10A circuit breaker as well as an LED that can indicate a phase inversion on the power supply line.
Product type | Power strip Main filter |
Connectors | 4x Filtered female Schuko 2x Unfiltered female Schuko |
Input voltage | 220-240V 50Hz |
Circuit breaker | 10A |
Output power | 2300W (230V) |
Dimensions | 430 x 305 x 100mm |
Housing material | Aluminium |
Weight | 6.15kg |
Color | Black |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
boualem d.
boualem d.
