No featrued products
Linear Power Supply Board 6x 10000µF 63V 50A
This large linear power supply module is equipped with a massive QL5010 diode bridge with a heat sink, as well as 6 Nover 63V capacitors of 10000µF each, ensuring a high filtering capacity. The module supports a high current of 50A.
| Specifications | |
| Product type | Linear power supply |
| Rectifier | QL5010 |
| Capacitors | 6x Nover 63V 10000µF |
| Current | 50A |
| Input | Screw terminal |
| Output | Screw terminal |
| General | |
| Dimensions | 186 x 72 x 72mm |
| Mouting holes spacing | 178 x 64mm |
| Weight | 452g |
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 63.0 |
| Output current (A) | 50.0 |
| Input voltage (V) | N/A |
| Power Supply | Regulated Linear Power Supply |
