ALLO USBRIDGE SIGNATURE Audio Streamer Raspberry Pi Compute 3+ Ultra Low Noise USB Interface
The Allo USBridge Signature is a network drive based on an SBC Raspberry Pi Compute 3+ and the DietPi operating system. It allows to reduce the noise of the Pi Compute and all the circuits to a minimum, thus enjoying the purest and most transparent reproduction possible.
By buying this product you get 27 loyalty points
Reference : 14122
279,00 €tax incl.
232,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Lecteur Réseau Raspberry Pi Compute Diet Pi Interface USB Faible Bruit
The Allo USBridge Signature streamer is based on a Raspberry Pi Compute Module 3+ SBC (Single Board Computer), offering this system great versatility. The DietPi operating system is pre-installed, and will allow you to easily access your entire audio library on the network or locally (USB storage).
The purpose of this module is to reduce noise on the USB bus as much as possible in order to provide the purest, most accurate and richest sound reproduction possible. For this purpose, the USBridge signature carries an excellent USB control chip from TI and the Ethernet circuit is completely separate from the USB circuit, thus limiting interference. In addition, noise has been reduced on each power rail through the use of more than 30 LDO controllers. Even the power rail of the Micro SD port has its own LDO. Thus, the module does not include any switching elements that can generate noise.
As the USBridge Signature is based on a Pi Compute, Allo has chosen to integrate all the available connectivity on a standard Raspberry Pi, namely a GPIO port, USB-A, HDMI and a Micro SD slot. Therefore, anything that works with a Raspberry Pi will work with the USBridge Signature. For example, it is quite possible to use the digital interface Allo DigiOne or DigiOne Signature (sold separately) to extend the connectivity of the USBridge Signature.
Review and presentation by The Hans Beekhuyzen Channel
Product typeStreamer
SBCRaspberry Pi Compute Module 3+
OSDietPi (On MicroSD Card)
Inputs3x USB-A 2.0 Host
1x Gigabit Ethernet RJ45
1x Slot Micro SD
Outputs1x USB-A (delivers up to 900mA)
1x HDMI
Supported sampling ratesPCM up to 768kHz / DSD up to DSD512 (DSD1024 theoretically possible)
Ethernet ChipsetAX88179
Ethernet bandwidth330Mbs
USB protectionAll USB Host ports include overload protection
Power supply5V 3A via USB-C
Dimensions150 x 119mm
CertificationsFCC
CE
InputRJ45
InputMicro SD
OutputHDMI
DAC / ADC ChipNC
Max sampling rateDSD1024
Max sampling rateDSD512
Max sampling rate768kHz
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsWeb radios
2 reviews
Bon produit
Le centre d'étude audio de allo est situé à Toulouse et ça se ressent dans la qualité de leurs produits. Après un petit rodage (deux semaines quand même), le usbridge a réglé mon problème de balance gauche droite sur mon système : la stéréo a été améliorée. J'utilise Moodeaudio et le usbridge est irréprochable par rapport à un RPI 3B+. Il est réellement fait pour l'audio.
This review has been posted for ALLO USBRIDGE SIGNATURE Audio Streamer Raspberry Pi Compute 3+ Ultra Low Noise USB Interface
Allo USBridge Signature works amazing beautiful!
I bought this last Sunday, usbsignature and a ALLO Aluminium Case for USBridge Signature
I have try dietpi first and that is good with roon , only I'm going to Ropiee and it works beautiful!
Wow ,this is recommended
The Allo USBridge Signature is a network drive based on an SBC Raspberry Pi Compute 3+ and the DietPi operating system. It allows to reduce the...
