No featrued products
Speaker Indoor / Outdoor 2 Ways with Passive Radiator IP66 80W Black (Unit)
Using a passive radiator, Dayton Audio's IO8XT speakers are equally suited to indoor and outdoor use. They can be powered by a 70/100V amplifier for commercial installations or by an 8Ω amplifier for consumer use. A selector switch makes it quick and easy to choose an option to suit your use.
This model is capable of producing extended bass using a passive radiator for deep, punchy bass reproduction. The top end of the audio spectrum is reproduced using a 1" silk dome tweeter, offering fine precision in the midrange and treble.
What's more, the IP66 protection rating and ABS chassis of these loudspeakers make them ideal for outdoor use, as they will not be affected by the elements or adverse weather conditions.
The IO8XT are supplied with brackets for vertical or horizontal mounting, and can be rotated for quick, easy and practical installation.
| Specifications | |
| Product type | Passive speaker |
| Power handling | RMS : 80W @ 8Ω Max : 160W @ 8Ω |
| Frequency response | 38Hz - 20kHz |
| Impedance | 8Ω |
| SPL | 87dB 2.83V/1m |
| Loudspeakers | Passive radiator 8" Silk dome tweeter 1" |
| Protection class | IP66 |
| General | |
| Dimensions | 38*25*24cm |
| Weight | 6.3kg |
| Color | Black |
| Quantity | Unit |
| Color | Black |
| Impedance (Ω) | 8 |
| Efficiency / Sensitivity (dB) | 87.0 |
| Lowest frequency (Hz) | 38 |
| Highest frequency (Hz) | 20000 |
| Power (W) | 80.0 |
| Number of ways | 2 |
| Number of loudspeakers | 2 |
| Speaker type | Passive |
| Speaker form factor | Other |
