MARTIN LOGAN MOTION FOUNDATION B1 Bookshelf Speakers Walnut
Small in size but not in sound, the Martin Logan Motion Foundation B1 bookshelf speakers are the brand's most compact solution, yet still capable of delivering unprecedented performance.
By buying this product you get 83 loyalty points
Reference : 18930
830,00 €tax incl.
691,67 € tax excl.
Martin Logan Motion Foundation B1 Bookshelf Speakers 2 Ways 100W 5 Ohm 48Hz - 23kHz Walnut (Pair)
Martin Logan Motion Foundation B1: 3/4 view
The S Gen2 Obsidian Folded Motion tweeter, Folded Motion waveguide and 5.5" aluminum-membrane bass/midrange driver work together to create a stunning, impressive experience while maintaining a compact footprint.
The Martin Logan Foundation range
The Martin Logan Foundation range redefines accessibility by integrating several of Martin Logan's renowned high-performance technologies, all at an affordable price. Drawing on 40 years of design and technical prowess, and offering incredible performance, the Foundation range represents an excellent gateway to the world of HiFi. It's the ideal foundation for a highly efficient stereo or surround sound system.
Martin Logan loudspeakers are renowned for their exceptional articulation, detail and realism, whatever the listening environment. Using advanced driver and controlled dispersion technologies, Martin Logan offers a unique listening experience.
Martin Logan Motion Foundation B1 : Tweeter
Martin Logan Motion Foundation B1 : Tweeter S Gen2 Obsidian Folded Motion
The Gen2 Obsidian Folded Motion tweeter delivers incredible sonic performance, unmatched by conventional technologies. By folding an ultra-thin material, Martin Logan is able to increase the emissive surface area in a small space. Large surface area, low weight and low excursion mean an incredibly fast and responsive tweeter, capable of reproducing the most nuanced content with stunning detail and clarity.
Martin Logan Motion Foundation B1 : Folded Motion Waveguide
Le waveguide des Martin Logan Foundation B1 assure une parfait contrôle de la dispersion du tweeter, couvrant la zone d'écoute avec des détails et une précision incroyables. Celui-ci évite également les réflexions de la pièce qui nuisent aux performances et fournit un son plus cohérent sur une zone d'écoute plus large.
Martin Logan Motion Foundation B1 : Waveguide du tweeter
Martin Logan Motion Foundation B1: Bass-midrange driver
Martin Logan Motion Foundation B1: bass-midrange driver with aluminum cone
Using technology from Martin Logan's Motion XT and Motion ranges, the B1s take advantage of the exceptional properties of the aluminum diaphragm to maximize mid-bass driver clarity, detail and efficiency.
Martin Logan Motion Foundation B1: Surprisingly compact
Martin Logan Motion Foundation B1: Dimension diagram
Product typeBookshelf speakers
Number of ways2
Frequency response48Hz - 23kHz
Tweeter dispersion90° (vertical) x 90° (horizontal)
Sensitivity89dB
Impedance5Ω
Crossover frequency3400Hz
Tweeter dimensions2.54 x 2.39cm
Midbass driver dimensionsØ14cm
Midbass driver materialsAluminum cone
Cast aluminium salad frame
Bass-reflexRear port
Power handling15 - 100W
Dimensions (W x D x H)18.41 x 24.05 x 34.64cm
Weight5.2kg / unit
ColorWalnut
PackageSold by pair
ColorWood
ColorWalnut
Impedance (Ω)5
Efficiency / Sensitivity (dB)89.0
Lowest frequency (Hz)48
Highest frequency (Hz)23000
Power (W)100.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
MARTIN LOGAN MOTION FOUNDATION B1 Bookshelf Speakers 2 Ways 100W 5 Ohm 48Hz - 23kHz Walnut (Pair)
Small in size but not in sound, the Martin Logan Motion Foundation B1 bookshelf speakers are the brand's most compact solution, yet still...
