SHANLING UA2 PLUS Portable Balanced DAC USB-C ES9038Q2M 32bit 768Khz DSD512 Silver
Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the very average audio output of a standard consumer phone, the Shanling UA2 is a transportable and affordable solution for playing your high resolution audio files anywhere without carrying  more than necessary.
Reference : 16871
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 13-08-2025.
Shanling UA2 PLUS
Portable Balanced DAC USB-C ES9038Q2M 32bit 768kHz DSD512 Silver
Shanling UA2 Plus DAC Symétrique USB-C ES9038Q2M 768kHz DSD512
Whether you're using a next-generation smartphone with no analog audio output (compatible directly with your headphones) or simply want to upgrade the audio output of a consumer phone, the Shanling UA2 Plus is a portable and affordable solution for playing your high-resolution audio files anywhere without taking up more space than necessary.
This new version of the UA series is equipped with increased decoding capabilities with an independent amplifier stage also offering a balanced output now in 4.4mm jack format.
High fidelity audio circuit
Although very compact, the Shanling UA2 Plus features a supercharged circuit built around an ESS ES9038Q2M chip, a reference component for high fidelity applications integrating both digital to analog conversion capabilities.
On the DAC side, the UA2 Plus is capable of playing high resolution audio files up to 32bit 768kHz and even DSD files up to DSD512 with native support.
The output stage is articulated around an RT6838 chip capable of developing a power up to 125mW under 32 Ohm with a minimal noise level, which represents an incomparable gain in comparison with the traditional audio outputs of mobile & consumer multimedia devices.
Shielded cable
The integrated cable has high purity copper conductors & high section ensuring excellent conductivity for your audio streams. It is solidly protected by a robust sheath and has a cotton/silver insulation specially designed to limit the capture of high frequency waves, such as those specifically present near a smartphone.
Product typePortable DAC
Inputs1x USB-C
Outputs1x Single-ended stereo Jack 3.5mm
1x Balanced stereo Jack 4.4mm
Output powerBalanced : 195mW @ 32Ω
Single-ended : 125mW @ 32Ω
Frequency response20Hz - 50kHz (-0.5dB)
THD+N0.0008% @32Ω (A)
Dynamic rangeBalanced : 120 dB @32Ω (A)
Single-ended : 122 dB @32Ω (A)
SNR
Balanced : 116dB @32Ω (A)
Single-ended : 121dB @32Ω (A)
Crosstalk
Balanced : 109dB @32Ω
Single-ended : 76dB @32Ω
Output impedanceBalanced : 1.6 Ohm
Single-ended : 0.8 Ohm
ColorSilver
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or...
