EMI / RFI mains filter Interference suppression 230V 1A
Reference : 8393
3,90 €tax incl.
3,25 € tax excl.
This EMI / RFI filter considerably limits mains signal interference to allow your high sensitivity / high precision audio devices to operate in the best conditions.
It is positioned directly between the electrical network and the transformer in charge of supplying your devices.
The module supports a maximum current of 1A and is ideally used with a fuse.
Wiring
Click on an image to enlarge
230V transformer
THD sous 10W @ 8 Ohm
2x115V transformer
THD sous 25W @ 8 Ohm
Technical drawing
Dimensions & spacings
TypeEMI / RFI mains filter
Max amperage1A
Spacings4.5 x1.5mm
Dimensions21 x 49mm
Weight10g
Markings on PCB
LPhase
NNeutral / Line zero
EEarth equivalent to GND
Rated current (A)1.0
