LHY AUDIO Low Noise DC Regulator
This LHY Audio 3.3V 1.5A low-noise voltage regulator module uses the recommended integration method of the Analog Devices LT3042 + PNP high-end regulator. This provides near-zero noise voltage regulation and a high output current of 1.5A. It can therefore deliver a pure power supply for DACs, high-precision measuring instruments, noise-sensitive RF applications and much more, with a ripple of just 0.6µVrms. What's more, the module accepts two input modes: DC or AC.
Reference : 20717
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 02-09-2025.
LHY Audio LT3042+PNP Low Noise DC Regulator LT3042 3.3V 1.5A
LHY Audio voltage regulator module
Diagram of LHY Audio voltage regulator module Noise measurements on the LHY Audio voltage regulator module
Product typeVoltage regulator module
Output voltage3.3V
Output current1.5A
Voltage regulator chipLT3042
RMS Noise0.8µVrms (10Hz to 100kHz)
PSRR79dB @ 1MHz
Bandwidth1MHz
Dropout voltage350mV
Supply voltage3.3-20V DC
3-13V AC
Dimensions39 x 82 x 29mm
InputSolder pad
OutputSolder pad
Output voltage (V)3.3
Output current (A)1.5
Input voltage (V)3.3
Input voltage (V)20.0
Input voltage (V)13.0
Input voltage (V)3.0
Power SupplyVoltage regulator
LHY AUDIO Low Noise DC Regulator LT3042 3.3V 1.5A
This LHY Audio 3.3V 1.5A low-noise voltage regulator module uses the recommended integration method of the Analog Devices LT3042 + PNP high-end...
