AUDIOPHONICS AP310-PREAMP Balanced Preamplifier MUSES72320
Audiophonics is proud to present the AP310-PREAMP, a pure analogue balanced preamplifier. Combining comfortable power with a MUSES72320 volume control and full connectivity, this preamplifier is a sure bet for anyone wishing for a quality sound system.
4.9 / 5
By buying this product you get 34 loyalty points
Reference : 19540
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 02-04-2026.
Audiophonics AP310-PREAMP Balanced Preamplifier MUSES72320
AUDIOPHONICS AP310-PREAMP : 3/4 view
Audiophonics AP310-PREAMP : An exhaustive range of connectors
The AP310-PREAMP has a full range of connectors to integrate easily into your audio system and adapt to your needs. Its rear panel features a stereo 3-pin XLR input and four stereo RCA inputs, one of which bypasses the volume control. On the output side, you'll find two outputs, one stereo RCA and one 3-pin XLR, also on the rear panel.
AUDIOPHONICS AP310-PREAMP : Connectors
AUDIOPHONICS AP310-PREAMP : MUSES72320 chip
Audiophonics AP310-PREAMP : MUSES72320 volume control
The volume control built into the Audiophonics AP310-PREAMP features a high-quality MUSES72320 chip. This stereo electronic volume controller offers excellent performance with a very low level of noise and distortion, thanks in particular to its resistor ladder circuit.
Audiophonics AP310-PREAMP : Modern, sober design
The Audiophonics AP310-PREAMP is housed in an aluminium shell that perfectly protects its components. Optimum heat dissipation is ensured by a series of openings in the cover and rear panel, allowing air to circulate freely. The front of the AP310-PREAMP features a magnificent black acrylic panel, a modern and elegant aesthetic touch. Behind this panel is a beautiful OLED screen, which displays the volume level, the active input and the type of signal received by the device. It also lets you navigate the menus and access all the AP310-PREAMP's options.
Audiophonics AP310-PREAMP : Great practicality
The AP310-PREAMP is also designed to be as user-friendly as possible. It incorporates a trigger input and output, so you can integrate it into a complex sound system without having to switch it on independently of the rest. Furthermore, a remote control is included, allowing you to control your AP310-PREAMP entirely from a distance.
AUDIOPHONICS AP310-PREAMP : remote controle
Audiophonics AP310-PREAMP : Volume control bypass
Line input 4 bypasses the volume control stage completely. When this input is active, no compensation or attenuation is applied to the audio signal before it is sent to the amplifier. Therefore, the source used with line input 4 must have its own volume control.
This input has been designed to insert another preamplifier or source with its own volume into the system. For example, a home cinema amplifier or a network player.
The default Trigger IN selects this input. This makes it possible for another device to switch on and select this input automatically. But it is also possible to change the input that the trigger will control in the device options to suit your use.
Never use line input 4 without first connecting it to a source with a volume control. Otherwise, the fully amplified signal could damage your equipment.
Entrée Bypass
Audiophonics AP310-PREAMP : Connectors
AUDIOPHONICS AP310-PREAMP : numbered connection diagram
1Balanced XLR male stereo output
2Single-ended stereo female RCA output
3Stereo balanced XLR female input
4Single-ended female stereo RCA inputs
5RCA bypass input (max fixed volume)
6Trigger input
7Trigger output
8Power input
9Fuse
10Power switch
Product typePreamplifier
Inputs1x Balanced 3 pins stereo XLR
4x Single-ended stereos RCA
Outputs1x Balanced 3-pin stereo male XLR
1x Single-ended stereos RCA
Volume range-90dB - +12dB
Gain settingsAdjustable up to +6dB
OLED screenBrightness not adjustable, but switches off after 40 seconds
Input impedance10kΩ
Output impedanceSingle-ended : 100Ω
Balanced : 200Ω
Output levelSingle-ended : 9.5V RMS
Balanced : 19V RMS
Amplification chipLM4562
Output levelSingle-ended: 9.5Vrms
Balanced: 19Vrms
Impédance de sortieSingle-ended: 100 Ohms
Balanced: 200 Ohms
Power supply100-240V AC
Stanby power consumption0.1W
ColorNoir
Dimensions295 x 220 x 65mm
Weight1.560kg
HousingAll brushed aluminium / Black acrylic front
Package1x Audiophonics AP310-PREAMP
1x Remote control (batteries included)
1x Power cable
InputXLR
ClassN/A
Remote ControlYes
15 reviews
Audiophonics AP 310
Je trouve cet audiophonics AP 310 excellent. Aussi bon que mon Xindak CA-1 avec moins de souffle et plus défini que mon Vincent SA-T1. Avec mon système sonore très sensible, sur base très haut rendement Altec, JBL et Fostex, j'obtiens le meilleur résultat en posant une masse de 125 grammes sur son capot. Une masse inférieure me donne trop d'aigus et une masse supérieure me donne trop de graves.
This review has been posted for AUDIOPHONICS AP310-PREAMP Balanced Preamplifier MUSES72320
AP310, incredibile!
L’Audiophonics AP310 si conferma un pre pulito, neutro e silenzioso, capace di gestire il segnale senza aggiungere nulla e senza perdere controllo. Proprio per valorizzare questa impostazione ho scelto, pur non avendone un reale bisogno, di ordinare anche il finale AP300 S250ncx. Per fare un setup di riserva. Non è ancora arrivato, quindi non posso valutarne l’accoppiata, ma l’obiettivo è semplice: completare la catena con un finale coerente e all’altezza della trasparenza dell’AP310. Questo pre l'ho inserito in una catena hiend al posto di un blasonato pre da 2mila euro "moderno" e devo dire che sono davvero stupito!
Stra consigliato, da inserire in catene dove si vuole che la firma sonora arrivi dalla sorgente ed eventualmente ravvivare vecchi finali fin troppo "musicali".
très bon préamplificateur transparent et l'entrée n°4 très pratique (préamplificateur hattor mini brancher dessus ) et la télécommande très pratique
Stripi
An exceptional product! The temporary Tannoy V1 Mercury speakers were oozing. Bass and treble as on some other speakers. When I silence the system the details are still present. Incredibly! How will it be when I hook up the Linton 85 Heritage? Esotericism!
OK.
A very simple preamp with good number of inputs. Enclosure is robust and it looks good. Unfortunately I received mine with a defective display but it was fixed.
Only bigger issue is the frustrating volume control when using the remote: at first the volume changes slooowlyyy... and then after a second or so it starts to run fast AF. Why no make it linear? Impossible to change the volume quickly. The rotary encoder on the device is responsive and precise but devices like this are usually operated with the remote.
Soundwise I have no complaints.
Audiophonics is proud to present the AP310-PREAMP, a pure analogue balanced preamplifier. Combining comfortable power with a MUSES72320 volume...
