FX-AUDIO TUBE-03 Valves 6K4 Stereo Preamplifier Black
Introducing the all-new 6J1 FX-Audio TUBE-03 tube buffer preamplifier. The latter now offers bass and treble tuning accessible from the front.
4.6 / 5
Reference : 12400
38,90 €tax incl.
32,42 € tax excl.
Shipping date: 15-10-2025.
FX-AUDIO TUBE-03
Tubes preamplifier 6K4 Stereo Black
fx-audio tube-03 préamplificateur à tubes
Introducing the all-new 6K4 FX-Audio TUBE-03 tube buffer preamplifier. The latter now offers bass and treble controls accessible from the front.
This TUBE-03 acts as a clever little tool to improve the sound of a desktop DAC or HiFi installation lacking punch. With a gold-plated stereo RCA stereo input and output, it will be a quality companion coupled with a class D power amplifier to restore dynamics and sound to any missing installation.
At the proposed price, this device has qualities usually absent in this category.
Moreover, this preamplifier does not have the caricatural sound impastoed in the lower midrange of classical tube productions. On the contrary, the terms transparency, dynamics, musical untiedness, sound matter are the ones that immediately come to mind.
An entry level excellence for any enthusiast who wants an affordable tube preamplifier of high quality.
Output power2000mW
Impedance600Ω
Frequency response20Hz to 20kHz
SNR100dB
Input sensitivity300mV-2000mV
Gain Max : 6dB
Output level Max : 2.7V RMS
Compatible tubesEF95
6AK5
6J1
Connectors
InputsGold plated RCA
OutputsGold plated RCA
Power supply connector formatJack DC 5.5/2.5mm (5.5/2.1mm compatible)
Dimensions100 x 95 x 32mm
Weight480g
AccessoriesPower supply adapter 220V to 12V DC 1A
ClassTube amp
25 reviews
Un bon niveau pour un petit prix
J'ai changé les tubes et ça fait déjà un grand pas pour 20€ de plus. Juste mon soucis avec ce préampli je n'ai aucune idée de la position à mettre pour le réglage de basse et trebble afin de ne pas influer sur le son et le garder neutre comme un préampli sans modification de fréquence. Je ne veux même pas choisir à l'oreille ma préférence, je veux laisser neutre! Je ne pense pas que c'est position mini... peut être que je me trompe aussi! Le service après vente ne m'a pas répondu sur ce sujet et je n'ai pas de matériel pour faire ces mesures ni démonter ! Les vidéos ne parle pas de ça non plus... j'espère un jour avoir une réponse basée sur des mesures ou la réponse du constructeur.
This review has been posted for FX-AUDIO TUBE-03 Valves 6K4 Stereo Preamplifier Black
Intéressant
au vu du prix je n'avais pas grand chose à perdre. Après m'être équipé d'un MPA-S250NC j'avais envie d'ajouter un petit quelque chose un peu moins "numérique" à mon ensemble malgré avoir un DAC.
En soit de base le son est très correct mais j'avais un buzz sur une enceinte, j'ai préféré une autre paire de tube, ce qui a réglé le problème et amélioré la qualité sonore, j'ai également changé les Op amp et je suis très content du résultat, j'ai gagné en dynamisme et en chaleur, ce ne révolutionne pas non plus mon installation mais ca lui donne le petit truc que je cherchais en plus.
BIZARRERIES APRES UN CERTAIN TEMPS D'UTILISATION...
L'enthousiasme suscité par ce petit préampli lors des premières utilisations a laissé place aujourd'hui à des doutes, en effet mes deux lampes neuves Jan 5654 se sont brutalement dégradées après seulement deux mois d'utilisation (à raison d'une heure de musique par jour), l'aigu est devenu hyper acide, insupportable, et le médium maigre, sans saveur. Je se sais pas si c'est le préampli qui a détérioré prématurément les tubes et je n'en écarte pas la possibilité car le niveau de sortie de cet FX-Audio Tube 03 est quand même très élevé (trop?). En remplaçant les tubes par des 6J1 (ceux d'origine) la restitution n'est pas vraiment bonne avec un aigu certes doux mais un grave manquant sérieusement de définition et de transparence. Bref je suis revenu à une liaison directe DAC-Ampli.
bien mais...
j'ai commandé ce petit appareil pour avoir la possibilité de calmer un peu la partie médium de mon ensemble, c'est mieux en diminuant un peu les aigus mais il ne faut pas trop baisser au risque de perdre trop, un réglage pour les médium aurait été plus pertinent et j'ai vu trop tard que ça existait. concernant les lampes je n'ai pas remarqué un son plus chaud qu'avant, après un moment de chauffe par contre la scène sonore s'élargie un peu plus et c'est très bien, le rendu est plus doux. suite à ce que j'avais lu, j'ai laissé allumé une journée, résultat je ne le referai pas, je pensais qu'une fois une certaine température était atteinte l'écoute serait stabilisée ben j'ai trouvé le son encore plus agressif comme si l'appareil ne faisait plus effet, résultat je le coupe en même temps que le reste et ça va mieux. je pense que je testerai les autres tubes. j'ai fait une comparaison sur mon installation avec un autre modèle sans lampes mais avec réglage médium en plus, une catastrophe, medium utile mais même en laissant les boutons sur midi les voix étaient trop en retrait et son étouffé et en activant le bypass quelle claque, le son est redevenu vivant et les voix présentes. j'ai rebranché mon fx audio et c'est bien mieux quand même. les réglages aigus sont bien calibrés, mettre au milieu pour démarrer, le volume est bien aussi calibré pas de mauvaise surprise ( inséré entre un préampli Atoll pr200 et un ampli 3Dlab Nano ) surtout ne pas oublier l'ordre de la mise en route, à l'allumage fx audio en premier et ensuite le reste, et à la fin de l'écoute éteindre tous les appareils en premier et le fx audio en dernier sinon gros bruit dans les enceintes ( et ça fait peur ) .
j'avais une panne de mon préampli de "moyenne gamme" (environ 800€) et voulais aussi bien /mieux
j'ai demandé conseil et j'avais des doutes "pas assez cher"
résultat vraiment surprenant et heureux , ne pas hésiter , j 'utilise une alimentation IFI audio ,aussi sur les conseils de David Aubert
prenez avis auprès d'Audiophonics
