jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
Customers reviews - There are 20865 reviews.
Sedat B.
Sedat rpi4minidac
I had a problem with my setup as I was very newbie in electronics, I lost the screen display and remote control, but the volumio works and the sound is excellent and now I am waiting for help from the technical team with my problem
Lars N.
Amazing sound
This DAC together with a Raspberry Pi 4b and LibreElec OS (Kodi) is a fantastic combination.
You can play Tidal/Spotify with Airplay or high res music thought USB media.
Carefully selected this DAC to be the source in my extreme setup
I use a 12V/85Ah AGM battery with a 5,1V/3A custom built voltage regulator as power source.
The power amplifier is a custom built Jean Hiraga class A design, also battery powered iwth 2x12V/85Ah AGM battery.
There are no noise at all even close to the speakers.
The soundstage is wide open and tight with realistic sound.
Placement of instruments/voice in the soundstage is stunning.
The bass is really deep and treble soft but natural.
I can really recommend this DAC, it´s true what Audiophonics say, this DAC has an outstanding sound.
Carlos N.
Pour un montage propre cet accessoire est indispensable
Carlos N.
Câble absolument incroyable
Dynamique, texture, étendue du grave, médium incroyablement beau avec beaucoup de matière, aigus. Ce câble se marie à la perfection avec un ampli à tubes triode, le mariage des 2 est magique et encore plus magique si on le raccorde avec une enceinte à haut rendement là s'est carrément diabolique. Ce câble pour moi fait partie des très grands câbles, le mariage du mono brin et de l'argent est tout simplement une idée de génie. Bravo Atohm et aux ingénieurs qui l'ont conçu.
Très belle fabrication avec des prises XLR de première qualité
Pourquoi dépensé plus alors que ce câble outre sa qualité de fabrication offre un résultat sonore excellent. Cela fait plaisir de pouvoir s'offrir du très bon matériel sans ce mettre à mal avec son banquier. Merci Audiophonics
Terje R.
Terry
All I can say is, Fast delivey and great quality!
Terje R.
Terry
Terje R.
Terry
Jean Claude V.
furutech
ses fiches bananes sont d une qualité extra
rien a redire la qualité ca se paye
Jean Claude V.
ferrite
site toujours aussi rapide
très bon produit de qualité
Carlos N.
Utilisation en 12v AC
Je n'ai pas acheté ce câble pour câblé des HP mais pour câblé une alimentation 12v alternatif d'un pré amp phono Cambridge car quand on voit le câble fourni d'origine avec l'alimentation pour des questions de budget on ce pose des questions. Ce câble convient parfaitement aux alimentations 12v AC qui est suffisant souple malgré le mono brin cuivre. Du 0.5 mm ² a la place de 0.15 mm² fait tout de suite une différence sur la partie audible du pré amp phono, une sensation d'aération général en découle. J'y ai joint une ferrite au niveau du connecteur du pré amp phono. Ne dégage aucun bruit parasite audible.
Carlos N.
Excellent câble pour le prix
Le grave descend plus bas avec mon ampli à tubes, une sensation de naturel, d'aération général, la scène sonore est très large. Excellent rapport qualité-prix.
Luis V.
200 Watts ??
I have purchased 2 of these amplifiers with 2 of the respective SMPS240QR Switching Power Supply at +-65V, it’s impossible to get even the power of 50W for these amplifiers, when the volume goes upper then 30% the amplifiers shut down or go in protection mode. I can´t really understand why this is happening even with other speakers, so in my understanding its a 30 Watts amplifier module instead of the 200 W the manufacturer claims.
I connect them to several pairs of 8 Ohms speakers with the same results.
The sound is very good but remember to play at low volumes if you buy this product.
Guillaume t.
Belle qualité
Petit filtre simple et efficace, utilisé pour ma part dans un projet DIY d'amplificateur casque Bluetooth classe A.
Meilleure aération de la scène sonore.
Fred F.
Merci Audiophonics !
Comme d'habitude chez Audiophonics : conseils avisés de M.David Aubert qui ne cherche pas à vendre à tout prix des produits plus chers mais s'adapte parfaitement à vos besoins, câble de grande qualité qui remplace un câble moyenne gamme avec des prestations exceptionnelles pour le prix. Ce Canare Star Quad ouvre totalement la scène sonore sans artifice. La neutralité, c'est ce que je recherchais.
A acheter les yeux fermés et les oreilles ouvertes !
pierre a.
bon produit , excellent rapport qualité/prix je recommande
Ab c.
super
Perfect price quality, fast shipping.
Only iec cable not included.
philippe d.
Tout bon !
Produit conforme, envoyé immédiatement, arrivée comme prévu : un sans faute !
H. d.
Very nice product, but there's room for improvements
This is a good quality power distributor with solid sockets. I very much like the fact that you can add your own powercord of choice.
However:
The lack of rubber feet on the bottom or so-called "bumpons" was a bit disappointing. Later I discovered an option on the website to add the bumpons to your order for an additional 1 euro. I had to order them seperately afterwards which costs a lot more. I.m.o. the bumpons should be included as standard.
For installing into cabinets it would be nice to have some sort of optional mounting brackets that click into the grooves on both sides of the unit.
william l.
FX-AUDIO DAC-X6 MKII DAC Headphone Amplifier Bluetooth 5.0 aptX ES9018 QCC3008 24bit 192kHz Silver FX-Audio X6 MKII is an ideal solution for your compact, affordable and high-performance audio systems. It works both as a DAC with volume control and headpthone...
Trés bien ! Mais...
Reçu rapidement, et aussitôt branché.
Fonctionne très bien, reconnaissance Bluetooth immédiate et la qualité plus que correcte.
Mais la finition des nouveaux produit FX AUDIO à baissé, le bouton du volume à pas mal de jeu et fait "cheap". L'alimentation et vraiment indigne, je ne laisserai pas ce type d'alimentation branché en permanence sur le secteur.
Gérard R.
5 étoiles oui, mais.........
Raccordé soit à ampli transistorisé ou à tubes, fait entendre soit de la ronfle soit des bruits bizarres en absence de modulation suivant position du potentiomètre. La solution a été de mettre un transfo pour supprimer la boucle de masse. Plus de bruit, très bon son.
Un bon transfo coûte aussi cher que le préampli lui-même. Dommage que ce point n'ait pas été mieux traité.
Nous avons détecté le soucis sur certaines unités, nous avons apporté une modification pour le corriger.
Teus V.
Amanero digital
It's a nice product and good for a dac
Damien M.
prix rétractable !
La qualité première de cette gaine , est d'en donner 2 fois moins (après l'avoir chauffée), et si le produit fait bien le "Job" inutile de s'appeler "Crésus" pour se l'approprier".
De surcroit la vente au mètre est un principe vertueux .
achetez les yeux fermés , vous n'aurez pas à vous rétracter, le produit le fait pour vous.
Mathieu w.
Amelioration
En plaçant cette alimentation sur un rippeur INUOS j'ai gagné en bande passante en précision Redécouvertes de certains titres favoris
TRISTAN A.
Je cherchais un dispositif peu onéreux pour écouter occasionnellement YouTube ou des radios sur ma chaîne à partir de mon smartphone en Bluetooth. Ce Fiio BTA30 comble mes attentes. Il délivre un son d’excellente qualité que je ne pensais pas trouver vu sa taille et surtout son prix.
Fabien S.
Mon système a gagné en clarté avec ce cable qui semble être le meilleur. De très bonne facture et bien que un bit soit un bit, les câbles numeriques comptent dans un système. Très satisfait.
Luc S.
Câbles HP DIYS
Très bon matériel dans la catégorie, je monte des câbles propres sans soudure ! Le service Audiophonics toujours impeccable .
bonne surprise .
le prix est derisoire et le produit de qualité.
la soudure est aisé , petite précaution quand au diamètre de perçage , effectivement pour trouver un forêt de 11,7 mm bonne chance , moi je vous recommande vivement de percer à 11,5 et finir avec une lime demi ronde .
Gordon D.
Very worthwhile
Bluetooth in aptx-hd from phone (andoid) or linux desktop. Toslink feed into teac ha-p50se or fiio E17. Really notice the SQ improve with the hd codec. They say xq-sbc codec (linux) is as high- quality as aptx-hd, but to my ears, aptx-hd is much finer quality.
On phone, the connection works well over several meters, less on the laptop. This device lasts me about 12h in RX mode.
Very happy with this product. I can fully recommend. Shipping to Finland was easy and hassle free. Item arrived within about 8 days.
Roberto G.
mechanical issues
Same thing here. I bought them but still the same issue. The mechanical design is weak: to block the cable there is a simple screw that punches the cable and risks to break the internal wiring.
Roberto G.
ETI NEXUS Silver Plated Tellurium Copper Male 3 Poles XLR Connector Ø8.5mm (Pair) Nexus ETI XLR connectors offer a very good design quality, integrating copper machined contacts with a small quantity of Tellurium. In addition, there is a silver plating of the...
mechanical issues
The mechanical design is weak: to block the cable there is a simple screw that punches the cable and risks to break the internal wiring. Go Neutrik or Furutech, it is wasted money to use this.
Cyrille V.
Cable
Evoute différente du Sommercable utilisé précédemment... rendu plus live et dynamique
Cyrille V.
Cable
Bien au-dessus du real cable que j'utilisais précédemment
Prix très raisonnable par rapport au gain
Miklos B.
I split my review into three chapter, 1, product and service, 2, sound quality, 3 power rating
1, I have ordered the amp. on a weekend, received the following Friday. At other sources you should calculate minimum 2-4 weeks lead times! So, the speed of delivery was absolute fantastic! Well done! Thank you! Everybody mentioning of the packaging, because there is no special hard paper box, but we get double box with filling material, which is safe enough. The product itself is very solid, nicely built and looks even better in reality than on pictures. Well done! Thanks a lot!
2, I had to wait with this review a week, because I had to find the right cabling. I made the change for this amp from an Emotiva XPA Gen2. When I simple changed them and used the same cables I have got quite week sound. So I started the big changing /fine tuning/ process. Making the long story short, I have changed each cable, selected them out from many alternatives, creating a formerly not used combo from the power cord trough out the USB cable, the RCA digital signal cable, the XLR analog cable and finally the speaker cable. By this process I finally arrived to a very capable, decent, detailed, extreme clean sound which I did not hear from my system so far. Thanks a lot for this!
3, Regarding the power level. The Emotiva papered 500 wpc at 4 ohms. The Purifi rated 425 wpc at 4 ohms. In real life that should not be felt so differently. But if I want to reach the same feeling of sound pressure with the Purifi like with the Emotiva, I need to turn up the DAC/Preamp volume controller from 50% to 75% and at the same time the Windows volume controller from 40% to 50%. ( the Tidal volume controller than can stand on the same place) . So according to my subjective feeling the wpc different is rather around 150 watt instead of 75 watt, which can mean that either the Emotiva delivers more or the Purifi less. ( or both at the same time )
Anyhow, this amplifier absolutely worth the money! Well done, thanks again!
Nils B.
C'est du tout bon
ce câble n'a pas besoin de mon avis. Mais en tout cas c'est un bonheur depuis qu'il est branché.
Génial !
Connecté avec des prises VIBORG or/argent et branché sur un vieux lecteur cd pionner ( décénnie 1990) ; un résultat d' un grand naturel une scéne sonore qui se déploie ; des détails intégrés de façon homogéne , on est pas loin de la réalité ; du bonheur ! bravo à audiophonics ( attendre une dizaine d'heure de rodage et ne pas hésiter à modifier les réglages de votre instalation : position des enceintes , position des piétements anti- vibratoire sous vos appareils si vous en posséder car ce nouveau venu pourra bouleverser votre instalation )
olivier r.
845 pas 845B
Les 845 B n'ont pas de top mica. Il s'agit donc la d'une 845 de base avec une embase décorée, c'est tout.
Raymond M.
Un peu moins dubitatif...
Un bémol à mon avis initial : j’ai déplacé le Clear Line du socle onduleur vers la multiprise située en amont. Résultat, l’aspect coloration-brillance a disparu, et j’ai retrouvé la ‘neutralité’ initiale de mon écoute, tout en ayant un peu plus de dynamique et d’ouverture. Donc c’est super, et je rajoute une étoile, mais pas deux, car je confirme, l’amélioration n’est pas à tomber à la renverse en ce qui me concerne. J’ai une super config, pas aussi top que Christophe L, mais il y a peut-être quelque chose qui ‘bloque’ le Clear Line. En plus du bloc onduleur, mon PC est un gros ‘transportable’ avec son ‘gros’ bloc alim. Il n’est pas directement sur le secteur. Est-ce tout cela qui s’accumule, pour donner un courant secteur déjà pas mal optimisé ? Mystère audio…
Dominique P.
Reçu rapidement et soigneusement emballé le produit semble de bonne facture et les mesures précises. Seul bémol: la notice entièrement en idéogrammes (chinois?) et le boîtier en plastique cassé dans un coin.
Théodore M.
5/5 rapport qualité prix écoute
Acheté pour remplacer du QED Ruby anniversary trop court suite à une nouvelle disposition. Reliés en bicablage avec des Furetech au niveau de l'ampli et des Hicon à mes enceintes (Elac bibliothèques). Sans vouloir rentrer trop dans les détails en comparaison moins de spacialisation (rodage ?) mais plus de précisions sur les petits signaux et des instruments plus fidèles. Également une dynamique plus fine au niveau de la séparation et l'aération entre pupitres ainsi que des prolongations de fin de notes plus longues dès qu'on prête l'oreille... Essayés chez un ami sur des petites colonnes Rodgers ces câbles se sont révélés là aussi très fidèles et précis. Pour avoir mieux il faut y mettre bien plus cher, on ne devrait pas être déçu sur une chaîne de moyenne gamme (3500 à 6000€) quelle qu'elle soit.
Théodore M.
Acheté pour remplacer 'IEC Elecaudio branchée sur ma barrette secteur Supra. Elle permet de monter facilement des câbles de plus grosse section (en l'occurrence Yarbo SP-8000PW de section 4,6 mm2). Par contre ne tiens pas assez fermement dans l'embase IEC de la barrette du fait de la rigidité du câble (je compte refaire l'embase en attendant de pouvoir acheter une meilleure barrette).
Théodore M.
10/10 !
Qualité des contacts excellente, coût raisonnable et super pratique pour le branchement du câble de la barrette secteur à la prise murale (Furetech) et derrière mon ampli.
Théodore M.
rapport qualité prix 5/5
Acheté avec des Schuko et IEC Elecaudio pour remplacer les câbles d'alimentation Supra (ampli, lecteur CD, Tuner). Amélioration immédiate sur tous les plans : rapidité sur les petits signaux qui apporte de la précision dans les attaques et fin de notes prolongées, meilleure spacialisation etc...
Je suis passé sur un Yarbo SP-8000PW sur mon ampli pour un gain encore meilleur sur l'ensemble de l'écoute (demande de courant supérieure car 1 transfo torique par voie + 1 pour la partie préamplificatrice à tube). Le tout en peaufinant les détails (prise murale Furetech pas donnée mais de grande qualité).
Raymond M.
Dubitatif et pas trop convaincu...
J’ai mis un peu de temps avant de donner mon avis, car je suis bien embarrassé et moins dithyrambique que les 6 autres avis postés (sans parler de l’annonce sur le site Furutech) …
L’écoute paraît un peu plus dynamique, un peu plus ouverte, mais aussi un peu plus colorée, moins neutre, et c’est cela qui me gêne, car cette ‘brillance’ annule quelque peu mes investissements en câbles (dual USB et Noir Hybrid de chez Forza Audioworks) pour connecter mon Dac-Ampli Audio GD R2R et mon casque HiFiMAN Sundara. Mon écoute se fait au casque sur mon PC avec Audirvana, où tout est déjà pas mal optimisé (2 JitterBug Audioquest pour l’USB, cordons secteur améliorés, le tout branché sur un bloc prises onduleur APC 700). Peut-être est-ce ce bloc onduleur qui rend ce Clear Line ‘peu spectaculaire’ ?
Mais je ne regrette nullement cet achat. Au vu des avis élogieux, j’aurais plus regretté d’être passé à côté d’une amélioration supplémentaire dans mon ‘mécano’ audio… Là au moins j’ai testé !
Je vais continuer les comparaisons et essayer de me convaincre de cette ‘dernière’ … amélioration, mais pour être franc, j’hésite à la conserver côté audio, et vais faire un essai sur la barrette secteur côté vidéo, histoire de finaliser son utilisation.
Anne b.
désoxydant
produit excellent pour beaucoup de contact je le conseille a tout les audiophile
Anne b.
fiche secteur
fiche secteur de bonne qualité je monte beaucoup plus dans les graves le médium est amélioré vraiment bien
Sandy Clémence B.
Sandy Clémence B.
borniers
très bonne qualité.
Robert V.
Robert V.
Composant comme décrit.
