Refurbished product - Grade S
Brand new product.
Reducer with Ferrite 11 to 9.5mm
The Ferrite cores attenuate the interference that occurs between the conductor, insulation and shielding of coaxial cables. This model has a black anodized aluminum body surrounding the Ferrite. The inlet of the reducer accepts cables up to 11mm, its outlet up to 9.5mm.
Product type | Reducer with ferrite |
Materials | Aluminum + Ferrite |
Input diameter | Up to 11mm |
Output diameter | 9.5mm |
Total dimensions | Ø20 x 40mm |
Length (m) | N/A |
Max cable diameter (mm) | 11.0 |
Section (mm²) | N/A |
Conductors material (Cable) | N/A |
Refurbished Grade | Grade S |
