ELBAC 944545-S0 Ethernet RJ45 Cat.6A Female Connector Shielded Ø9mm
This RJ45 Cat.6A female connector will allow you to design Ethernet extension cables. The assembly is done easily without crimping pliers. The connector accepts cable diameters ranging from 6mm to 9mm.
Reference : 17030
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 13-05-2025.
Elbac 943545-S0
Elbac 943545-S0 Connecteur RJ45 Ethernet Cat.6A Femelle Blindé Ø9mm
This RJ45 Cat.6A female connector will allow you to design Ethernet extension cables. The assembly is done easily without crimping pliers. The connector accepts cable diameters ranging from 6mm to 9mm and conductor sizes from 0.129mm² (26AWG) to 0.326mm² (22AWG).
Product typeFemale RJ45 Cat.6A connector
Contacts platingGold 50µm
Body materialNickel plated cast zinc alloy
Max bandwidth10Gbps
POE++ support
Dielectric strength (1min / 60Hz)Contact to contact : >= 1000V
Contact to shielding : >= 1500V
Insulation resistance≥ 500MΩ
Contact resistance≤ 20mΩ
Transmissible current1.5A max
Lifetime≥ 750 insertion / extraction cycles
Dimensions (L*P*H)24*37.6*17mm
Max cable diameter (mm)9.0
Mounting typeN/A
ConnecticFemale
ConnectorRJ45
This RJ45 Cat.6A female connector will allow you to design Ethernet extension cables. The assembly is done easily without crimping pliers. The...
