Source selector Audio / Video RCA 4 to 1 reversible
This switch is an inexpensive solution for connecting up to 4 audio / video devices to a television set, projector or sound system. A digital marking corresponding to the RCA inputs facilitates the identification of the source
3.0 / 5
Reference : 13488
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 22-08-2025.
source selector RCA x 4 IN / OUT RCA x1
4x Audio 2ch + Video
Source Selector AV
This switch is an inexpensive solution to connect up to 4 audio / video to a TV, projector, or a sound installation.
It allows a permanent connection between multiple sources (up to 4) to a single main device.
Once the source selector integrated into a complex audio system, just press the push button switch corresponding to the current source.
In addition to the comfort of being able to change source without affecting connections, this type of device is particularly useful for increasing the life of the mechanical parts of the installation (connectors, plugs, cables), since these will be less prone to frequent handling.
Select source
The source selection is made by a panel of four buttons on the front.
Each mechanical button acts on a spring mounted on PCB selector for switching the signal.
A digital marking with the RCA inputs facilitates the identification of the source
Selector audio source
TypeSource Selector
Power supplyPassive
inputsStereo RCA X4
x4 video
OutputsStereo RCA X1
x1 video
Mode selectionPushbutton
HousingMetal
Dimensions140 x 73 x 38mm
Weight314kg
2 reviews
Simple et efficace
Simple à brancher, fait des clics satisfaisant lorsqu'on bascule d'une source à une autre. Rien à redire, c'est exactement ce que je voulais.
This review has been posted for Source selector Audio / Video RCA 4 to 1 reversible
mauvais contacts
Selecteur pas cher mais bas de gamme. Souvent une voie ne fonctionne pas à moins de manipuler le poussoir. Pas vraiment recommandé.
This switch is an inexpensive solution for connecting up to 4 audio / video devices to a television set, projector or sound system. A digital...
