J'ai eu un problème avec une défaillance sur l'un des tubes.
Le SAV m'a proposé plusieurs solutions au choix.
Il y a un grand respect des clients
The Mullard GZ34 tube is a high-end direct-heated rectifier diode. It is the re-edition of Mullard's most popular rectifier tube ever. Its purpose is to extend the life of other amplifier tubes by allowing them to heat up before voltage is applied.
Product type | Tube |
Tube type | Rectifier |
Number of pins | 5 |
Dimensions | 87mm x Ø29.6 mm |
ELECTRICAL CHARACTERISTICS | |
Heater current | 2.1A |
Diode anod current | 180mA - 280mA @ filament voltage 5,0 V, plate voltage 17 V |
Rectified current | 180mA @ filament voltage 5,0 V, plate voltage 17 V |
First and second diodes plate current difference | ± 30 % @ filament voltage 5,0 V, plate voltage 17 V |
MAX VALUES | |
Filament voltage | 5.5V |
Rectified current | 250mA |
Anode current amplitude | 825mA |
Current surge at the turn -on moment | 3.7A |
Anod reverse voltage amplitude | 1500V |
Temperature at the most heated part of the envelope | 200°C |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean François N.
Vladimir p.
