FURUTECH GT2 NCF USB-A Male / USB-B Male Cable 1.2m
With the GT2 NCF, Furutech offers a USB-A to USB-B cable with a silver-plated OCC copper conductor and triple shielding. This cable also benefits from the NCF technology developed by Furutech, which coupled with the materials used and the meticulous design it has undergone, makes it an exceptional cable.
By buying this product you get 22 loyalty points
Reference : 19361
220,00 €tax incl.
183,33 € tax excl.
FURUTECH GT2 NCF USB-A Male / USB-B Male Cable Silver-plated OCC Copper 1.2m
FURUTECH GT2 NCF : Front view
Furutech GT2 NCF : NCF sheath
At the heart of the GT2 NCF is an NCF connector sleeve. With a hybrid multi-material construction, this innovative sleeve exploits a special crystalline NCF (Nano Crystal² Formula) material from Furutech with two ‘active’ properties: firstly, it eliminates static electricity by generating negative ions, and secondly, it converts thermal energy into far infrared. Furutech enhances this material with nanometric ceramic particles and carbon powder, taking advantage of their piezoelectric damping properties.
Furutech GT2 NCF : Silver-plated OCC copper and triple shielding
Precision engineered, the GT2 NCF features silver-plated OCC α (Alpha) copper conductors and high-density polyethylene insulation for optimum signal transmission. Its triple shielding and 24K gold-plated USB 2.0 connectors minimise electromagnetic interference and offer foolproof protection against oxidation.
Furutech GT2 NCF : Alpha α treatment
The conductors that make up the GT2 NCF cable benefit from a two-stage Alpha cryogenics and demagnetisation process. Firstly, the conductors undergo deep cryogenic freezing using top-of-the-range refrigerants such as liquid nitrogen or helium. Once temperatures of between -196 and -250C° are reached, the conductors are subjected to internal stress, forcing the molecules that make them up into tighter bonds, resulting in a more stable overall structure and improved conductivity. In a second stage, the conductors are exposed to a ring demagnetisation treatment patented by the brand.
Product typeUSB-B to USB-A cable
ConnectorsUSB-B
USB-A
Length1.2m
DiameterØ6.4mm
Conductor materialSilver-plated OCC copper
Connector plating material24k Gold
InsulationHigh density polyethylene
ShieldingAluminised mylar foil
Al Mylar
Braided conductor treated α (Alpha)
ColorPurple
Package1x FURUTECH GT2 NCF
Length (m)1.2
ShieldingYes
Section (mm²)N/A
ConnectorUSB-A
ConnectorUSB-B
Excellent upgrade from Supra Excalibur
I have owned this cable for a while now and compared it against Supra Excalibur, the original Supra USB, Oyaide neo d+ Class S, and Neotech Neub 1020. I haven't heard the old Furutech GT2 version without NCF, but from what I've read from others this is a significant improvement over Furutech's old USB cable.
Comparing directly against the other USB cables I mentioned it's most similar in style to Supra Excalibur, but also a clear upgrade in quality. Supra Excalibur has a firm style of sound that emphasizes slam and punch. It's also a bit flat in soundstage quality compared against the other cables. The most common complaint about Supra Excalibur is that it's excessively firm and as a result feels unnatural and somehow dead and sterile. I think Furutech GT2 NCF delivers everything that's good about the Supra Excalibur while fixing all the flaws. It's not a small difference, as I think the perceived upgrade in sound quality matches the price, ie it's 2x the cost for what easily sounds like 2x the sound quality. Let's say that Supra Excalibur adds 80% firmness the original sound, then Furutech GT2 NCF dials it down to maybe 15% extra firmness. You get more physical presence and punch, but without overdoing it. The reference I'm using here is Neotech Neub 1020, which emphasizes the air more but also might be a bit too laid back and gentle. The Furutech GT2 NCF feels roughly similar in quality, but different in style as it give you extra physicality. For most people I think the Neub 1020 will be better, and it also feels better for my audiophile brain to be using pure silver conductors instead of silver plated copper used by the Furutech GT2 NCF. But I can't deny that the GT2 NCF sounds amazing, and I think the NCF technology is effective in cleaning up problems in the signal. I think Furutech have done a great job with this cable. The quality of sound matches the price. I think on some systems this will be clearly better than Neub 1020, so you should seriously consider it. Because I use USB reclockers I'm using both Neub 1020 and GT2 NCF in my system with great results.
This review has been posted for FURUTECH GT2 NCF USB-A Male / USB-B Male Cable Silver Plated OCC Copper 1.2m
With the GT2 NCF, Furutech offers a USB-A to USB-B cable with a silver-plated OCC copper conductor and triple shielding. This cable also benefits...
