Hard to make a study connector. My soldered connection broke at use.
No featrued products
Gold Plated Male USB-C 3.1 DIY Connector
This connector to mount will allow you to create your own cables with gold-plated USB-C connectors. This will allow you to take advantage of the reversible format of this connector, which can be plugged in both directions without making mistakes. In addition, USB-C takes advantage of the USB 3.1 standard for higher transfer rates. The connector is delivered with a plastic housing, to be glued.
| Specifications | |
| Product type | Male USB-C Connector |
| USB Standard | 3.1 |
| Plating | Gold |
| OTG | No |
| Mounting | To solder (DIY) |
| Dimensions (without housing) | 15.8 x 8.3 x 3.5mm |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Male |
| Connector | USB-C |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
Average votes 3.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
