No featrued products
LM7812, Adjustable, +12V / +25V
This discrete voltage regulator has been designed to replace an LM7812 IC model (or LM7815 / 7818 / 7824 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +12V is adjustable in the range +12V to +25V by means of a potentiometer. This controller provides low ripple, low noise and fast response. The controller only uses high-quality components such as a Toshiba low noise triode, Vishay resistors, VX Tantalum capacitors or a Bourns precision potentiometer.
| Specifications | |
| Product type | Discrete voltage regulator |
| Adjustable output voltage | +12V to +25V |
| Output current | 1A |
| Operating temperature | 0°C - 125°C |
| Dimensions | 13.843 x 16.383mm |
| Output voltage (V) | 17.0 |
| Output voltage (V) | 24.0 |
| Output voltage (V) | 21.0 |
| Output voltage (V) | 16.0 |
| Output voltage (V) | 23.0 |
| Output voltage (V) | 19.0 |
| Output voltage (V) | 14.0 |
| Output voltage (V) | 15.0 |
| Output voltage (V) | 20.0 |
| Output voltage (V) | 12.0 |
| Output voltage (V) | 22.0 |
| Output voltage (V) | 18.0 |
| Output voltage (V) | 25.0 |
| Output voltage (V) | 13.0 |
| Output current (A) | 1.0 |
| Input voltage (V) | N/A |
