No featrued products
LM7912, Adjustable, -12V / -25V
This discrete voltage regulator has been designed to replace an LM7912 integrated circuit model (or LM7915 / 7918 / 7924 with pre-setting), in order to provide your audio system with a cleaner electrical signal. Its value of -12V is adjustable in the range -12V to -25V by means of a potentiometer. This controller provides low ripple, low noise and fast response. The controller only uses high-quality components such as a Toshiba low noise triode, Vishay resistors, VX Tantalum capacitors or a Bourns precision potentiometer.
| Specifications | |
| Product type | Discrete voltage regulator |
| Adjustable output voltage | -12V à -25V |
| Output current | 1A |
| Operating temperature | 0°C - 125°C |
| Dimensions | 13.843 x 16.383mm |
| Output voltage (V) | -23.0 |
| Output voltage (V) | -16.0 |
| Output voltage (V) | -25.0 |
| Output voltage (V) | -18.0 |
| Output voltage (V) | -20.0 |
| Output voltage (V) | -13.0 |
| Output voltage (V) | -22.0 |
| Output voltage (V) | -15.0 |
| Output voltage (V) | -24.0 |
| Output voltage (V) | -17.0 |
| Output voltage (V) | -19.0 |
| Output voltage (V) | -12.0 |
| Output voltage (V) | -21.0 |
| Output voltage (V) | -14.0 |
| Output current (A) | 1.0 |
| Input voltage (V) | N/A |
