Linear Voltage Regulator 15V 1A
The MC7815BTG is a voltage regulator that can be used for many applications. This controller uses an internal current limiter and thermal protection. With a suitable heat sink it can deliver a current of 1A. Initially designed as a fixed voltage regulator, it can also be used with external components to obtain an adjustable voltage and current.
Product type | Linear voltage regulator |
Output type | Fixed |
Rated output voltage | 15V |
Output current | 1A |
Min. input voltage. | 23V |
Max. input voltage | 35V |
Case type | TO-220 |
Number of pins | 3 pins |
Min/Max operating voltage | -40°C / 125°C |
Output voltage (V) | 15.0 |
Output current (A) | 1.0 |
Input voltage (V) | 23.0 |
Input voltage (V) | 30.0 |
Input voltage (V) | 35.0 |
Input voltage (V) | 25.0 |
