Barco V.
Trigger 12v
Barco V.
Pavel V.
Very good streamer
Avis clients - Il y a 20154 avis.
Paul M.
Rock solid Neutrik quality adapter
Bough these to supplement my stock of connection adapters. Neutrik feel and Neutrik quality: rock solid build and connections. No signal degradation that I can hear. Recommended!
Paul M.
AUDIOPHONICS WIRE Câble de Modulation RCA Stéréo Cuivre OFC Plaqué Or 75cm La gamme Audiophonics Wire propose une sélection de câbles abordables mais pour autant performants, assemblés à la main dans nos ateliers, en France....
Solid quality cables - all you need
I use these cables between a streamer/dac and a power amplifier. The Mogami cable is supple and easy to route, also in the smallest of places. The Amphenol rca connector has a metal body and feels very solid. The Amphenol makes a tight (but not too tight) connection with the rca connections on both sides. Audiophonics is skillful in putting these cables together. Just choose the cable length you need and enjoy the music!
Paul M.
AUDIOPHONICS WIRE Câble de Modulation RCA Stéréo Cuivre OFC Plaqué Or 1.5m La gamme Audiophonics Wire propose une sélection de câbles abordables mais pour autant performants, assemblés à la main dans nos ateliers, en France....
Clive S.
AIYIMA A70 MONO Amplificateur Mono/Subwoofer Class D TPA3255+NE5532 1x300W 4 Ohm Le Aiyima A70 Mono est un amplificateur Class D qui repose sur un chipset composé d'une puce d'amplification TPA3255 et d'un AOP NE5532. Il est en mesure de...
Great little amplifier
It's kind of embarrassing for my old class AB amplifier
This little thing is connected to a 15 inch subwoofer and it makes the house shake. I'm considering buying another one just to try it in stereo mode with full range speakers.
Thierry V.
RAMM AUDIO ZEUS SI 15 Câble Secteur Schuko C15 Cuivre OCC Triple Blindage 1.5m Ramm Audio propose avec le Zeus SI 15 un câble d'alimentation audiophile de très grande qualité. Profitant d'une conception exceptionnelle, il intègre...
surprenant
Veritable aubaine a son prix, j ai des CS bien plus chers, ce Ramm les concurrence sans problème merci Audiophonics de nous donner accès à ce type de produit au RQP incroyable
Robert C.
EVERSOLO T8 Lecteur Réseau Transport Numérique WiFi 6 DLNA UPnP Roon Ready Bluetooth 32bit 768kHz DSD512 Le transport réseau Eversolo T8 permet de connecter votre installation HiFi en réseau pour profiter de sources numériques haute résolution....
Stunning music streamer
Pros:
Excellent audio signal output (especially I2S).
Easy configuration (in 10 minutes unit is ready for use).
List of supported music streaming services, apps and connectivity.
Silent unit (zero noise, black background).
Fast and stable mobile app.
Software updates.
Cons:
Upsampling feature (preferable in DSD) in future software releases.
Eemeli T.
OK.
A very simple preamp with good number of inputs. Enclosure is robust and it looks good. Unfortunately I received mine with a defective display but it was fixed.
Only bigger issue is the frustrating volume control when using the remote: at first the volume changes slooowlyyy... and then after a second or so it starts to run fast AF. Why no make it linear? Impossible to change the volume quickly. The rotary encoder on the device is responsive and precise but devices like this are usually operated with the remote.
Soundwise I have no complaints.
Eemeli T.
AUDIOPHONICS Trigger Séquenceur Actif 1 Entrée / 4 Sorties 12V Ce trigger séquenceur actif est un produit assemblé à la main dans notre atelier Audiophonics. Il permet d'éviter les plocs et les pics de courant...
Just the thing I have been looking for!
A simple and cheap solution to a problem of not having enough trigger outputs on my preamp. Now I can power on all my devices at once. The slightly delayed "soft start" is nice addition! Perfect little box and works just as promised.
David H.
Une révélation ! Le pilier de mon système haut de gamme
Configuration : Holo Audio RED (USB) DAC Audiomat Maestro 3 Ampli Aria EL34 NOS Carbon Cabasse Pacific SCS.
Avis détaillé :
J'ai intégré le Holo Audio RED en tant que Pont Réseau / DDC dans mon système Hi-Fi très exigeant. Je cherchais à optimiser la qualité du flux numérique avant mon DAC Audiomat.
Le résultat a dépassé toutes mes attentes.
1. Magie Opérée : Le son est devenu instantanément plus organique et réel. Le RED apporte un fond sonore plus noir qui permet aux micro-informations d'émerger sans effort. C'est le contraire d'un son "numérique" ou froid.
2. Synergie parfaite : Il a permis à mon DAC Audiomat Maestro 3 de s'exprimer pleinement, en lui fournissant un signal dépourvu de jitter et d'une stabilité irréprochable. La fluidité et la richesse des timbres de mon ampli à tubes (EL34 NOS Carbon ) sont sublimées.
3. Impact sur l'écoute : L'image stéréo (déjà excellente avec mes Cabasse Pacific SCS) est désormais plus tridimensionnelle et stable. La musique gagne en vie et en présence.
En conclusion : Le Holo Audio RED n'est pas un simple streamer, c'est un purificateur de signal numérique essentiel. Si vous possédez un DAC de qualité, cet appareil est un investissement justifié qui maximise le potentiel de toute votre chaîne. Un produit absolument sublime !
Gabriel G.
NEOTECH NEUB-3020 Câble USB-A Male/USB-B Male 2.0 OCC plaqué Or 24k 1m Le câble USB AUDIO class 2.0 Neotech NEUB-3020 offre une qualité de restitution numérique redoutable utilisant des technologies innovantes venant bousculer...
Naturel
J'ai les deux versions, argent et cuivre, de ce câble Neotech. Sur un DAC Audio-gd R1, je préfère utiliser le cuivre à l'argent en mode NOS. Extrêmement naturel, la musique coule sans frustration.
David H.
Fait parfaitement le travail
Un peut dure de rentre le 4mm2
David H.
Excellent fiche banane
J'ai choisi ces fiches bananes Dynavox pour leur bon rapport qualité-prix et leur placage or. Elles font parfaitement le travail et assurent une excellente connexion entre mon ampli et mes enceintes. Le système à double vis de serrage est efficace pour maintenir le câble en place, même avec une forte section.
Point à améliorer :
Le seul petit bémol concerne la gaine thermo-rétractable fournie. Avec mon câble de 4.0 mm2 (qui a un diamètre externe important), la gaine est un peu juste et ne permet pas d'avoir un serrage ou une isolation parfaitement ajustée à la sortie de la fiche.
Malgré ce détail esthétique et de finition, la performance électrique n'est pas affectée. C'est un excellent produit si l'on est prêt à accepter ce petit ajustement ,Recommandé pour le prix !
David H.
Meilleur choix home cinéma longue distance
Le meilleur choix pour le Home Cinéma et les longues distances !
Note : 5/5 (Excellent rapport performance/prix)
Ma configuration : Marantz Cinema 50 (7.1.2) et enceintes Cabasse iO2/Ki (Total 73 mètres de câble).
Mon expérience :
J'ai longtemps hésité avec des câbles audiophiles très coûteux, comme le Viard Audio Premium HD 4 mm2 (qui coûte environ 27€/m soit 8 à 9 fois le prix de l'Elbac).
Mon verdict est clair : L'Elbac HP240 est le choix le plus intelligent et performant pour un système Home Cinéma.
1. Techniquement Supérieur pour la distance : Pour mes longueurs (jusqu'à 11m)le critère le plus important est la faible résistance du câble. L'Elbac est conçu pour une faible perte de puissance, garantissant que mon Marantz garde un contrôle total des basses et de la dynamique. Sur ce point technique essentiel, l'Elbac est un excellent produit PRO.
2. Qualité d'écoute : Le rendu est dynamique, précis et maîtrisé. Les différences subtiles promises par le Viard (clarté des aigus, etc.) sont, au mieux, totalement imperceptibles dans un contexte multicanal 7.1.2, surtout lorsque l'ampli utilise la correction acoustique (Audyssey).
3. Le prix : Dépenser (1700€ de plus pour 73 m) de câble Viard qui n'apporterait aucun gain sonore garanti.
Michael S.
7HZ TIMELESS II Écouteurs Intra-Auriculaires IEM Planar Magnetic Ø14.5mm 15.2 Ohm 108dB 5Hz-40kHz Les écouteurs intra-auriculaires 7HZ Timeless II, évolution des Timeless de la marque, sont des IEM planar magnetic bénéficiant d'un nouveau driver...
Einfach super
Habe meine Bestellung gut verpackt und schnell nach Deutschland erhalten.
Der InEar ist von Preis/ Leistung top!!
Der Klang ist von tiefen Bass über Mitten bis hin zu den Höhen
präzise und ausgewogen,homogen.
Er benötigt jedoch etwas mehr Ausgangsleistung an meinem
Astel&Kern (Kann Max).Beste Grüße an audiophonics.fr M.S.
Jonas R.
Interface Numérique USB Amanero / Bluetooth 5.0 vers AES / SPDIF / I2S 32bit 192kHz DoP128 Cete petite interface numérique performante prend en entrée un signal Bluetooth 5.0 ou USB pour ensuite sortir au choix en I2S (via HDMI), AES, Optique Toslink ou...
Good USB to AES interface
Good Device. Plug and play.
Do note that if you plan to use Bluetooth as primary input you would have to select that on the box with a button every time the device has been turned off.
For my use case it is perfect.
Georges C.
HATTOR AUDIO THE BIG Préamplificateur Passif Symétrique Takman REX Noir / Argent Hattor Audio nous présente ici un préamplificateur passif symétrique High-End offrant d'incroyables performances grâce à une conception non moins exceptionnelle.
Hattor Audio The Big TakmanRex
Excellent appareil d'emploi très pratique ,musicalement encore supérieur à mon précédent" Music First Audio", particulièrement du point de vue de l'ouverture de la scène sonore. A recommander sans restriction. Merci à la maison de m'avoir fait découvrir une telle solution à mes embarras...
A la livraison, les deux cartons étaient en parfait état, mais curieusement la valise montrait une marque de choc et une fracture de la fragile paroi de façade, le préampli n'ayant en rien souffert
Gorazd K.
FIIO DM13 BT Lecteur CD Ripper sur Batterie 2xCS43198 Noir Le DM13 BT de FiiO est un lecteur CD portable à l’esthétique soignée et à la qualité des composants internes indéniable. Son...
As always, full praise to Audiophonics for their excellent packaging and fast delivery. The CD player is well-built and neatly packed, complete with a user manual. The aluminum body feels solid, and the buttons have a nice tactile feedback — overall, handling it gives the impression of a quality product.
The user experience, however, could be better. To change outputs, you have to go through a sequence of button presses. It’s not an issue for me since I’m a bit of a tech enthusiast, but for a less experienced user, it might be confusing.
When you plug in wired headphones, it doesn’t automatically switch from Bluetooth — you need to manually select the desired output. Another thing I miss is a Stop button. I’m not sure why it’s missing, but it would make the operation more complete.
Apart from that, everything else is fine — the sound quality is good and matches the price point.
Ratings:
Audiophonics: (5/5)
Build Quality: (4/5)
Ease of Use: (3/5)
Sound Quality: (3.5/5)
Mathias K.
AUNE AR5000 Casque Audio Dynamique Ouvert Ø50mm 28Ω 108dB 5Hz-41Khz Le casque audio AR5000 de la marque Aune est un casque ouvert à driver dynamique MLD ("Multi-Layer Distributed") de pas moins de Ø50mm. Grâce à son...
Très bon !
Je suis pleinement satisfait de ce casque ouvert facile à piloter, d'une bonne qualité de fabrication, plutôt léger et très agréable à porter. Il délivre un son clair, précis, très détaillé et réaliste. Je recommande.
Mathias K.
TOPPING DX5 II DAC 2xES9039Q2M Amplificateur Casque X-Hybrid Bluetooth 32bit 768kHz DSD512 Blanc Avec le DX5 II, Topping présente l'héritier direct de son célèbre DAC et amplificateur casque DX5. Cette nouvelle version apporte de très...
Excellent à tout point de vue
Pour un prix somme toute abordable, ce petit boitier réunit un excellent ampli casque et un DAC tout ce qu'il y a de plus transparent, aux performances exceptionnelles. Il intègre en plus des possibilités d'égalisation que je n'ai pas encore testé. Un sans faute.
Francis F.
SMSL PA-X Amplificateur Stéréo / Mono Infineon GaN 2x250W 4 Ohm / 1x500W 8 Ohm Le SMSL PA-X est un amplificateur innovant qui utilise des transistors à Nitrure de Gallium (GaN) pour offrir une amplification de 2x250W sous 4Ω. Sa polyvalence...
Ampli PA-X smsl
Je me suis informé, lu et écouté tous les avis possible que j ai pu trouvé avant de me décider à l acheter car c est un budget .
A ma grande surprise beaucoup de petits problèmes énoncés, n existe pas sur mon exemplaire . Il est relié à mes enceintes Davis Acoustics Klarence MV3 , et c est un vrai régal sonore . Je l ai comparé à mes anciens ampli class AB et il faut admettre qu il est plus détaillé et avec nuances et grave très présentés.
Il est piloté par un Viim pro , l ensemble est parfait . Un très bon achat , merci Audiophonics pour la livraison sans problème .
Daniel D.
AUDIO BASTION X-PAD REF Contrepointes Aluminium Acier Inoxydable Ø50mm (Set x4) Conçues en acier inoxydable polie à la main, aluminium T6061, oxyde de zirconium et silicone, ces contrepointes sont pensées pour réduire...
très bon rapport qualité/prix
suite à mon commentaire précédent, j'apporte les précisions suivantes. Pour pas cher, la scène sonore s'est encore améliorée légèrement en largeur , profondeur, détourage et vivacité en plaçant sous chaque contre pointe un sandwich de matériaux amortissants différents. A savoir sur les pieds avant de mes thiel CS 3.7 qui sont des enceintes closes avec face avant en aluminium et caisson en bois multiplis, 1 rondelle de 2mm découpée dans une semelle de chaussure, marque Noen, 1 rondelle de 5 mm en feutre un peu dur, 1 rondelle de 5 mm en feutre souple + 1 rondelle en liège souple de 1cm (déjà évoquée précédemment). Sur les pieds arrière, 1 rondelle en silicone dur de 15mm, 1 rondelle en feutre dur de 5 mm. La différence d'amorti pieds avant, pieds arrière influe uniquement sur la vivacité du rendu. Le sandwich permet d'amortir différentes fréquences. Faites vos propres essais...
OYAIDE NRF-005T Ruban Adhésif Suppresseur de Bruit Pulshut 4m Le Oyaide NRF-005T est un ruban adhésif anti-bruit utilisant le matériau PULSHUT® (textile non-tissé haute performance) développé par...
ETONNANT !
Produit très efficace qui apporte une précision d'écoute indéniable . Attention toutefois à appliquer au fur et à mesure car trop de ce produit à tendance à assécher le son . Après plusieurs essais sur câbles de modulation et secteur , seuls deux rubans ont étaient appliqués sur le premier câble secteur de ma barrette . Ne pas hésiter à tester plusieurs endroits de votre système et à en retirer si besoin . Idéal pour optimiser un système déjà upgradé ; ce sera la touche finale .
Franck y.
AUDIOPHONICS AP300-S500NC Amplificateur de Puissance Class D Stéréo Ncore NC502MP 2x500W 4 Ohm Le Audiophonics AP300-S500NC est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore NC502MP. Cette solution est...
De la puissance et de la finesse !
J'ignore qui a dit "sans maîtrise la puissance n'est rien" (cf Pirelli TV-Ad), mais Audiophonics a tout compris en choisissant ces modules Hypex. Ce qui m'a rassuré dans mon choix, ce sont les protections que cette carte intégre en cas de surchauffe, de surtensions et court-circuits.
La team Audiiophonics a fait un excellent travail avec cet ampli. Bravo et merci à eux. Comme d'habitude, j'ai été livré en 48 h.
Après 10 jours d'écoute, avec deux types de DAC, le SMSL DO200pro et le Fosi ZD3, et à la source des fichiers numériques essentiellement - compressés au minimum : flac et mp3 à 320Kbps - pour alimenter une paire de Prestige 4i - une colonne pése 30 kg - je redécouvre mes morceaux.
Je remarque de nouveaux détails ici et là sur la totalité du spectre. C'est une grande fenêtre qui s'ouvre à moi. Par exemple, le refrain de Proud Mary version I&T. Turner ne me fait plus mal aux oreilles. À ce moment du morceau, j'avais tendance à baisser le volume, quelque soit l'ampli. Les envolées funk rock devenaient trop brillantes/bruyantes.
Mais avec le S500NC d'Audiophonics, les aigus et les medium sont doux, détaillés, aérés et jamais criards.
Et l'intro sur ce même morceau, où le couple Turner vont chanter chacun à leur tour, la première chose qu'on remarque, c'est la puissance et la maîtrise dans le bas du spectre quand Ike déroule son "rooOOOooolling". Le timbre de ce "rolling" m'a tout de suite fait penser à un vieil ampli de classe A. J'avais un Linn qui pesait 12 kg et qui chauffait une pièce de 20 m2 l'hiver mais d'une musicalité envoûtante voire mystique. Chaque note coulait comme du bon miel chaud. On avait l'impression d'être dans le studio. Ou sur la scène entre le bassiste et les choristes.
Les transitoires propres et maitrisées du S500NC rappellent la linéarité des classe A, avec du jus, de la réserve en plus et de loin un meilleur rendement. Sans compter qu'il chauffe à peine, qu'il pése 2 kg et qu'il prend très peu de place.
Pour résumer, un ampli puissant qui délivre au moins 250 W sous 8 Ohms bien propres et quasiment sans distorsion - par canal - avec un son neutre et maitrisé, des aigus fins et précis, jamais agressifs, des medium clairs et fermes et des graves bien charpentés et planants en hifi comme home-cinéma à 699 euros, avec des composants et un assemblage de qualité, dans un beau châssis ni trop petit ni trop grand, c'est un cadeau qu'on aurait tort de se refuser.
Le meilleur compromis serait un petit ampli classe D pour la TV et la musique de tous les jours et un ampli classe D XXL pour une session d'écoute hebdomadaire ou mensuelle raffinée et de qualité. Pour conclure, avec un tel ampli et avec de bonnes colonnes, un caisson de basses est superflu.
pascal v.
FURUTECH LAN-8 NCF PLUS Câble Ethernet RJ45 Cat8 S/FTP 1.2m Le Furutech LAN-8 NCF Plus est un câble Ethernet RJ45 de Catégorie 8 avec blindage S/FTP magnifiquement conçu et pensé pour le transfert de signaux...
Un cable ethernet vraiment transparent
Câble furutech LAN8-plus acheté en remplacement d'un câble Ugreen 8.1 qui se trouve entre ma box et mon intégré Roksan Attessa. Après 1 semaine d'utilisation bilan très positif, la musique se libère , sur les bons enregistrements on a l'impression que cela respire entre les instruments. Du coté des voix cela sonne plus naturel. Ce câble est hautement recommandable, mais attention au système qui tire vers le haut, je pense que cela pourrait être désagréable. Mon Roksan au son typé Anglais (rond) est devenu beaucoup plus clair.
Balèze
Ce câble sort du lot. A la fois transparent et rapide mais surtout dispose d'un medium plein et organique. Son seul défaut : Rigide ! Monté vite fait avec une shuko IEGo or et iec Viborg or qui trainait pour adoucir tout ça et roule ma poule ! selon la formule galvaudée, je réécoute tous mes disques. Des notes posées des silences habités... J'ai des frissons en écoutant Stille Nacht de Cantate domino, une merveille de prise de son que je connais depuis 40ans quand-même. Dernière chose, il marche tout aussi bien sûr ampli que sur dac, donc polyvalent.
olivier r.
Mauvais
Son brouillon et oxydation du revêtement cuivre.
olivier r.
Cable fabuleux.
Permet d'accéder à des détails et de la finesse en profondeur. Médium à la fois étoffé et différencié. Mérite les meilleurs connecteurs. Enterre les bricoles bruyants à base de Duelund, Belden etc... Surpasse un Xsangsane argent 9001 grâce à davantage de structure et de matière tout en restant très fin.
Système déjà bien abouti à base de triodes et enceintes 94db.
Alexandre B.
SHANLING ONIX OVERTURE XM5 Baladeur Numérique DAP ES9039PRO 2x TPA6120 32bit 768kHz DSD512 Le Onix Overture XM5 de Shanling est un DAP haut de gamme conçu avec des composant à la pointe de la technologie afin de proposer les meilleurs performances...
Un petit bijou
Superbe DAP. La qualité de fabrication est excellente, très largement meilleure que celle du iBasso DX180 que je possède aussi. Tout est bien finit et bien pensé, particulièrement la roue de volume et le placement des entrées casque au bas de l'appareil. Côté son c'est du très bon, avec un fond sonore très noir, un son plutôt chaud, et une excellente musicalité. La batterie est excellente, l'OS aussi. Attention par contre, pas d'Android, c'est un lecteur essentiellement fait pour écouter des fichiers FLAC à partir de la carte SD. Seul Tidal est disponible pour le streaming audio, et en version basique qui ne permet pas de télécharger des morceaux pour une écoute hors ligne. Ce qui correspond exactement à ce que je cherchais. Livraison très rapide par Audiophonics.
Eric R.
OYAIDE DST-75R V2 Câble Coaxial RCA SPDIF 75 Ohm 102SSC Plaqué Rhodium 1m Le câble OYAIDE DST-75R V2 est un câble Coaxial RCA 75Ω de très haute qualité à l'architecture unique et assemblé avec des...
Est ce bien utile
bonjour
J'ai tenté l'expérience afin de ne pas passer à coté de quelque chose
J'ai donc fait la comparaison avec un câble optique à 10 balles afin de raccorder mon Technics SL G700M2 à l'ampli SU G700 , le tout raccordé sur des Triangle Magellan Quatuor anniversaire
Et bien ....... aucune différence ça reste du numérique , et c'est l'ampli qui fait le job pour passer en analogique , l'influence du câble , dans ce cas de figure, relève plus de psycho-acoustique qu'autre chose
Après c'est un câble bien assemblé , permettant une liaison propre , de qualité et sans doute durable
Il ne faut pas s'attendre à autre chose , pour cela j'accorde une étoile , pas plus , le reste étant du discourt marketing
Alessandro S.
VIBORG VE512G Connecteur Secteur Schuko Type E/F Cuivre Pur Plaqué Argent / Or Ø20mm Ce connecteur secteur Schuko Viborg VE512G profite d'une qualité de conception exceptionnelle, utilisant uniquement des matériaux de grande qualité pour...
De qualité mais compliqué
La prise est certainement de très bonne qualité, mais connecter le cable, surtout si de diamètre un peu important, est pas mal compliqué. Je crois qu'on aurait pu la concevoir mieux. Le coté IEC est beaucoup plus simple.
Ramiro F.
Cabo digital preciso e transparente
Excelente construção e transmissão limpa, com palco sonoro mais definidoe fundo silencioso.
Ligação estável e sem coloração-ótimo upgrade
Ramiro F.
ISOACOUSTICS ZAZEN I Plateforme Absorbeur de Vibrations 432x381x30mm 11.3kg Le IsoAcoustics zaZen, empruntant son nom à une méthode de méditation assise, est une plateforme d'absorption des vibrations conçue pour être...
Isolamento eficaz e elegante
A IsoAacoustics Zazen I melhora claramente a estabilidade e definição sonora, reduzindo vibrações sem complicações.
Acabamento de qualidade e instalação simples- excelente upggrade para equipamentos sensiveis, em particular o Mutec REF1O S120.
Ramiro F.
ISOACOUSTICS ISO-PUCK MINI Absorbeurs de Vibrations Ø44x24mm (Set x8) La gamme des ISO-PUCK de chez IsoAcoustics offre une approche innovante dans l'isolation des appareils Hi-Fi tels que des enceintes de salon, des moniteurs de studio ou tout...
Bom isolamento em tamanho compacto
Os IsoAcoustics ISO- PUCK MINI oferecem uma melhoria audivel na clareza e definição de som, reduzindo vibrações e ressonâncias indesejáveis.
São discretos , eficazes e fáceis de usar.
Uma solução excelente para equipamentos leves ou colunas de estante.
Yves M.
Génial
Je ne connaissais ni le produit ni même la marque avant cette acquisition. Le WiiM Mini est parfait pour redonner vie à des enceintes bibliothèque un peu vieillissantes, la diffusion depuis un Mac via Airplay 2 (et câble optique) étant franchement impressionnante. Belle finition, appli impeccable, que du bonheur.
Joseph P.
Tube E-Harmonix 12AT7WC
Très bon tube acheté pour tenter de le mixer avec un Philips JAN 12AT7 WC. Ce E-Harmonix produit un son plus chaud et rond la scène sonore est large et stable. Les percussions sont franches et profondes il envoie plus de volume sonore, mais il lui manque ce plus de finesse et de détails produits par le couple de Philips que j'ai préféré pour la beauté de ses aigus, (mais qui reste en retrait dans les décibels restitués). Très bon tube pour ceux qui préfèrent un son rond et chaud. Reçu super bien protégé et emballé, Grand merci à toute l'équipe d'Audiophonics .
Joseph P.
Très bonnes fiches Banane Viborg
Ressemblent beaucoup aux fiches Nakamichi. Elles sont un poil plus dures à insérer dans les plots ce qui garanti un excellent contact sans perte de signal. Par contre leur rapport qualité/ prix est imbattable. Merci Audiophonics
François D.
Ravi
J'ai renoncé à la sortie analogique et j'ai connecté le BerryBak sur mon DAC Topping E30ii via la sortie optique. Je suis ravi du résultat.
En outre, appairage Bluetooth facile et de très bonne qualité qui ne décroche même pas entre 2 étages !
Pierre J.
Clip pour Fixation Façade Enceinte Plastique (Unité) Ce clip vous permettra de fixer simplement et efficacement les caches de vos enceintes en façade.
remplacant idéal...
J'ai commandé ces clips pour pouvoir remplacer ceux qui étaient présent sur le panneau de protection des HP pour une enceinte colonne Klipsch.
En effet, ceux d'origine étant en plastique dur, ils se sont cassés un par un à force de de déposer en remettre le panneau de protection.
J'ai percé des trous plus grands pour pouvoir insérer ces clips et iles remplacent parfaitement ceux d'origine avec un meilleur maintien du panneau de protection HP.
gilles b.
FOSI AUDIO BOX X5 Préamplificateur Phono MM/MC OPA1612 Le préamplificateur phono Fosi Audio Box X5 est un petit appareil qualitatif acceptant les cellules MM et MC. Reposant sur l'utilisation d'OPA1612 en DIP8 et une...
Vraiment bon et bien conçu pour le prix ^^
Ce petit boitier Fosi X5 remplace avec efficacité un pré ampli phono Cambridge Azur 551P qui a un étage de pré amplification en classe A, ce X5 en version d'origine rivalise sans aucun soucis avec le 551P en plaçant le gain sur 38, si je commute le gain sur 48 j'obtiens une meilleure dynamique pour aborder mon pré ampli Lpass2 Prime (classe A) et en effet le X5 avec ce gain variable lui permet de se distinguer et d'obtenir un meilleur rendu selon la sensibilité de la cellule mais aussi de mieux s'adapter aux périphériques en aval (pré ampli et ampli de puissance), donc je trouve judicieux de la part de la marque Fosi d'avoir mis un sélecteur de gain qui rend le X5 plus flexible.
Je n'ai pas pu résister à la tentation de le faire évoluer, en remplaçant le banal opa 5532 qui est monté sur un socket dip8 et si vous êtes méticuleux je vous invite à le faire car l'opération d'ouverture du boitier reste assez simple, mais avant tout bénéfique quand on a la possibilité d'avoir en stock plusieurs types d'opa, j'ai donc testé 2 opa soit le LM49720 et le Burr Brown 2134.
Pour effectuer ce comparatif, j'ai choisi un morceau assez chargé en quantité d'instruments, et surtout avec une excellente prise de son, j'ai utilisé le logiciel Audacity avec ma carte son Roland et j'ai donc enregistré 2 fichiers audio en WAV que j'ai pu par la suite comparer en ouvrant les 2 fichiers dans un lecteur et en switchant de l'un à l'autre, puisque la commutation entre les 2 fichiers était rapide et efficace car mon comparatif a été concentré sur les 30 premières secondes du morceau qui comportait une introduction à la trompette et d'autres instruments qui venaient se greffer pour compléter la scène sonore.
J'ai exclus l'opa 5532 monté d'origine car il n'a aucun intérêt dans ce comparatif, toutefois le 5532 me servira de point de repère pour constituer une comparaison entre: 5532 VS LM49720 / 5532 VS BB2134 / et LM4972 VS BB2134.
5532 VS LM49720: le LM49720 apporte une dynamique largement supérieure au 5532, plus de matières mais le LM49720 propose à peine plus de précision et de détails car même si il est plus dynamique, le placement des instruments reste à l'identique du 5532, c'est plat et bien droit comme message sonore projeté mais çà manque de vie, en déduction le LM49720 apporte guère mieux que le 5532 hormis la dynamique et à peine plus de précision, le choix de mettre LM49720 dans le Fosi X5 ne me semble pas cohérent pour une si faible amélioration.
5532 VS BB2134: le BB2134 est sensiblement identique en dynamique au 5532, par contre il apporte tellement plus dans sa manière de détailler la musique que je ne vais pas m'étendre plus que çà car le 5532 n'est pas du tout à la hauteur pour tenter de rivaliser avec le BB2134 qui fait tellement mieux !! déjà on peut vite constater les limites du 5532 qui a mon goût est loin d'être assimilable à la catégorie de la musique haute définition, toutefois on trouve de nos jours le 5532 dans 90% des appareils d'entrée de gamme mais il bride tout simplement les performances.
LM49720 VS BB2134: le LM49720 conforte son aspect dynamique supérieur au BB2134 tout comme avec le 5532, mais c'est le seul point fort pour celui ci puisque je trouve que le LM49720 est trop brouillon en le comparant au BB2134, le morceau choisit débute avec un jeu de batterie qui passe de la gauche vers la droite puis il est suivi par la trompette avec des notes qui raisonnent avec un bel effet de sustain (maintien de la note jouée) et j'avais ce point repère grâce à la version CD qui respecte ces détails, cas de figure avec le LM49720 l'effet de stéréo de la batterie qui passe de gauche à droite est quasiment inexistant mais le pire c'est qu'il écourte la durée des notes de la trompette et là c'est la catastrophe car çà ne sonne pas naturel, pour autant le 5532 fait exactement la même chose avec une dynamique moindre.
Le BB2134 respecte la musique, en reproduisant à la perfection l'effet stéréo du jeu de la gauche vers la droite de la batterie, en maintenant la résonnance de chaque note de la trompette et surtout en respectant le timbre de la trompette qui sonne vraiment en merveille, car avec mes enceintes KLIPSCH RF5 (filtres full tweak Mundorf Suprême) une trompette qui sonne mal timbré avec les pavillons d'aigu et le haut rendement ! çà peut vite devenir difficile à écouter.
En conclusion, je suis très satisfait de ce Fosi X5 et encore plus enjoué quand je l'écoute avec le BB2134 qui apporte une belle évolution sonore, donc pour ma part je le considère comme un très bon rapport qualité surtout si on rajoute la modeste somme déboursée pour se procurer un opa BB2134, cet ensemble à faible coût n'a aucun soucis pour se distinguer de la concurrence quand on tient compte de la qualité des composants embarqués et en tenant compte aussi du sélecteur de gain qui est utile et rend le Fosi X5 adaptable dans un grand nombre de configuration possible.
Etienne c.
FOSI AUDIO P4 Préamplificateur Le préamplificateur Fosi Audio P4 est une solution compacte et polyvalente. Avec ses trois entrées RCA stéréo, son contrôle de volume avec...
Petit mais ...
très bon préamplificateur, simple " transparent ". Rapport qualité prix imbattable. A voir si le potard motorisé tiens le coup dans le temps .
Etienne c.
FOSI AUDIO V3 MONO COMBO Pack 2x Amplificateur V3 Mono + Réducteur de Bruit d'Alimentation + Adaptateur Secteur 48V DC 10A Avec le Mono Combo Pack, Fosi Audio propose un pack de produit taillé sur mesure pour une installation double mono. Ce dernier est composé de deux amplificateurs...
étonnant
Très bon amplificateur, un chouille généreux vers 100 Hz . Rapport qualité/prix 10 sur 10. Après ,la tenue dans le temps ???.
Luigi P.
VIBORG VB406G Fiches Banane pour FM Acoustics Cuivre Pur Plaqué Argent / Or 24K Ø6mm (Set x4) Les Viborg VB406G sont des fiches bananes dont les contacts sont en cuivre pur pour assurer un excellent niveau de conductivité. Par ailleurs, elles...
Wrong
Unfortunately the description misleaded me. These plugs are NOT standard . I was looking for plugs accepting cable size max diam 6mm but the plug itself is not standard one . I would have clearly reported the diameter for the connector anfor the plug rispectively! Bad luck Shipment timing and comunicationg during order preparation excellent on the other side.
Thierry V.
RAMM AUDIO AIR 25 Câbles de modulation RCA-RCA Cuivre OFHCC Plaqué Or 1.5m (La paire) RAMM Audio propose avec son AIR25 un câble de modulation RCA haut de gamme et abordable de 1.5m de longueur. Les conducteurs de ce câble sont en cuivre OFHCC et...
surprenant
Excellent! Rapport QP surprenant !..ce cable peut concurrencer des cable bien plus cher...matière , aération, richesse de timbres!
Cyril L.
Déçu, vraiment
Installation : DAC Fosi ZD3 + 2 amplis Fosi ZA3 en mono XLR.
Avant de monter l'ensemble (8x AOP pour la config complète) j'ai procédé au remplacement uniquement sur un ZA3 des 2 AOP sur les sorties RCA (R+L).
J'ai pu ainsi comparer entre un ZA3 d'origine et le 2e ZA3 avec les OPA2134PA.
Quelle déception à la vu des commentaires lui faisant éloges.
Si j'ai ressenti une meilleure définition des graves avec une dynamique plus précise, cela devient vite étouffant, trop de basses.
Les médiums sont globalement étouffés avec un effet de réverbération franchement dégu... désagréable.
Les aigus sont aussi étouffés avec une grosse perte de clarté si bien que certains passages de cymbales sont totalement oubliés à ma grande surprise.
Je ne tente même pas d'attendre une période de rodage, je ne pense pas qu'après 50 heures d'utilisation, le rodage arrive à corriger autant de défaut.
Difficile de croire pouvoir trouver un équipement pour les utiliser, il vont finir au placard. A ce prix et au nombre nécessaire pour changer ses équipement ça ne fait pas plaisir. Heureusement, je n'en ai pris que 4 pour tester.
Orienté pour les systèmes manquant de basses avec des médiums/aigus trop dominant.
José T.
DENAFRIPS PONTUS 15TH DAC R2R NOS Symétrique 1536kHz DSD1024 Noir Le DAC NOS R2R symétrique double mono Denafrips Pontus 15Th représente une excellente solution de conversion numérique/analogique high-end, offrant des...
Exceptionnel
Je viens du DAC SMSL D1 2x9038PRO qui a un son analytique et froid (c'est maintenant que je m'en rends compte)
Ici
1) le son est chaud
2) les basses apparaissent alors qu'elles étaient absentes avant
3) son pas fatiguant meme apres des heures
4) ouverture de scene totale
5) le son remplit toute la piece
Attention : apport surtout sur la musique acoustique, exemple sur DAVE FUNKY FRIDAY cela n'apporte rien
Synthèse : avez vous écouté la différence entre un ampli classe D et classe A? on a ici la meme différence entre un dac à modulation de fréquence et un dac à modulation d'ampliture
Arnaud B.
Câbles RCA Cuivre OFC Plaqué Or Canare L-4E6S 1m (La paire) Ces câbles RCA profitent d'une belle qualité de conception, avec notamment un câble Canare L-4E6S intégrant des conducteurs en Cuivre pour une section de 0.2mm² (24AWG).
Un bon câble équilibrée qui transmet le signal sans le travestir de quelque façon
Arnaud B.
GUSTARD X26III DAC 2x ES9039SPRO NOS Lecteur Réseau LAN Roon Airplay UPnP 32bit 768kHz DSD512 Argent Le X26III de Gustard est un DAC symétrique et lecteur réseau se reposant sur deux puces DAC haut de gamme ES9039SPRO afin de proposer une conversion du PCM...
Ce dac présente une signature sonore très équilibrée avec sonorité relativement douce chaude et fluide à l'image des puce AKM Velvet.
Je cherchais davantage de transparence et surtout aération aussi j'ai passé mon chemin ...
Elsa A.
Sélecteur de source XLR 3 pôles 2 vers 1 Cablage PTFE Cet appareil permet de relier plusieurs sources analogiques sur votre préamplificateur, votre amplificateur intégré ou vos enceintes passives.
Sélecteurs d'excellence
Je possède les deux types :
-2 sources vers 1 chaine d'amplification
-1 source vers 2 chaines d'amplification ou tout ce que vous aurez besoin de connecter en hifi en conservant les qualités de vos éléments.
Les 2 sélecteurs sont d'une parfaite transparence due au câblage impeccable multiple des prises XLR ; bravo Audiophonics!
Angelo M.
rapport qualité prix imbatable
Très bon produit, du cuivre que du cuivre, rien de mieux pour garantir une connexion propre. utilisées avec un câble ELECAUDIO HP-25OCC elle se sertissent sans problème pas besoin de souder
Angelo M.
utilisées sur un ampli Luxman L30
Très bien pour connecter des fiches bananes sur un vieux ampli. Restitution impeccable
