AUDIOPHONICS K214 V2 Class-A Stereo Headphone Amplifier MOSFET 250mW/ 16 Ohm
AUDIOPHONICS K214 Class-A Stereo Headphone Amplifier MOSFET 1000mW / 16 Black
4.9 / 5
Reference : 11023
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Audiophonics K214 V2
Headphone Amplifier class A
The AUDIOPHONICS K214 V2 headset amplifier has all the necessary refinements to make it an exceptional device.
Built on the basis of high quality components such as Dale resistors, Wima MKP capacitors, Hitachi K214 MOSFET, shielded transformer, MJ 15004 transistor driver, it offers an exceptional price/performance ratio.
This Audiophonics K214 V2 version offers a carbon track ALPS Blue model with 15,000 minimum wear cycles instead of the standard original potentiometer, providing greater reliability and even more fidelity.
It is capable of driving the vast majority of helmets on the market, including the most demanding ones (Orthodynamics, Studio Monitor, 600 Ohm, etc...). Its precision, generosity, warmth and multiple advantages make it a versatile and efficient headphone amplifier for music.
Note: Power cable sold separately.
schema
1Film MKP Wima Capacitor
2K214 Mosfet Class A Transqistors
3ALPS potentiometer
4Gold-plated RCA
5Low noise linear power supply
Signal to noise ratio100dB
THD0.005%
Gain16.5dB
Output impedance16 Ohms
Power250mW 16 Ohms / chan
450mW 32 Ohms / chan
supported impedances8-300 Ohms
Inputstereo RCA
headphone output6.35mm stereo
FrameBlack anodised aluminum
Dimensions160x140x45mm
Weight1.140kg
OutputJack 6.35mm
ClassClass A / AB
43 reviews
nickel
acheté pour remplacer un LD1+, il chauffe beaucoup moins, le son est riche, précis mais pas fatiguant, l'image stéréo est stable. Pas grand chose à lui reprocher, en dehors de la diode en façade un peu trop discrète (j'oublie parfois de l'éteindre)
This review has been posted for AUDIOPHONICS K214 V2 Class-A Stereo Headphone Amplifier MOSFET 250mW/ 16 Ohm
MISSION ACCOMPLIE !
Postulat de départ, m'équiper pour à peu près1000 € max ce qui est déjà une somme pour sublimer et profiter de la qualité audio de mes abonnements DEEZER et QOBUZ via ROON ce depuis mon PC, ayant la chance d'avoir une connexion internet stable.
Pour le DAC choix porté sur un EVERSOLO Z6 que je trouve génial, ça s'installe en 5 minutes téléchargement du driver inclus, mais dont la sortie casque n'est pas fameuse avouons le...Alors pour améliorer tout ça choix porté sur ce "petit" appareil...Et ça apporte vraiment un plus ! Le mariage entre ces deux appareils fonctionne parfaitement bien. Là encore simplissime d'installation, on branche sur le courant, on branche son câble RCA et roula ma poule. Difficile pour moi qui ne suis en rien spécialiste de décrire une qualité sonore, mais le résultat est bluffant surtout après quelques temps d'écoute, le fameux rodage ! Pour qui veut caresser le monde audiophile sans "trop" se ruiner, allez-y ! Il ne me reste qu'à me rapprocher de l'équipe AUDIOPHONICS pour me conseiller un casque de qualité pour compléter l'ensemble de ma petite installation qui pour moi me convient parfaitement. Bref bravo !
Un amplificateur audiophile basique
J'ai commandé le premier amplificateur Audiophonics K214 V2 le 24/11/2020, puis un deuxième qui arrive prochainement. Suite à un rodage de cent heures, le son n'était toujours pas chaud alors je l'ai gardé comme amplificateur de dépannage sans trop comprendre pourquoi le mien conservait un son froid, creux, analytique.
Je m’en suis servi de temps en temps et j'ai constaté une nette amélioration du son avec une chaleur bien venue. J'ai réalisé le test avec le casque Beyerdynamic DT 770 PRO qui m'avait servi pour le rodage de l'amplificateur à sa réception. J’ai d’ailleurs utilisé d’autres casques pour les tests. Ce casque semble être une bonne association avec cet amplificateur. J’ai utilisé mon PC et YouTube (la sortie est paraît-il en PCM 2.0). La différence entre le premier test et le deuxième est incommensurable. J’ai du mal à croire à un effet psycho-acoustique et je pense plutôt qu’il est question ici d’un vieillissement des composants utilisés car il est bien question d’un montage audiophile classique de classe A à transistor. Ce qui complique la donne, c’est que la source n’est pas stable comme avec du matériel HIFI classique en raison du fait qu’il est question d’un objet connecté supportant de nombreuses mises à jour, en l’occurrence Windows 10 puis Windows 11.
Il n’y a pas beaucoup d’amplificateur à transistor mais plutôt à AOP (Amplificateur Opérationnel), il y a également le MONOLITH LIQUID SPARK qui est à transistor mais il utilise des composants de surface plus modernes, il représente également une exception dans les amplificateurs pour casque dans sa catégorie.
Very good and soilid build quality! Very good sounding and lots of power!
The sound quality is very good, but the production in China is not flawless, because the stereo RCA channels are internally inverted! Therefor only 4 stars worthy.
Greetings
Excellent Ampli Casque
Bonjour
Acheté suite au conseil d'audiohonics pour piloter un AKG 702.
Je trouve après 3 mois d'utilisation que le mariage avec ce casque est réussi. Il ya assez de puissance ( potard à 10h max ).
Le rendu est assez neutre je trouve : essayé avec plusieurs DAC que je connais bien, il retranscrit les caractéristiques de chacun d'entre eux vers le casque.
Contrairement à ce que j'ai pu lire, il ne chauffe pas tant que ça, pour un classe A c'est vraiment normal et acceptable je trouve.
Si y a un point négatif à remonter c'est peut être une sorte de distortion audible dépasser un certain volume, mais là encore je cherche la petite bête car je vais jamais jusque là niveau volume sauf par curiosité c'est tout.
Pour moi c'est un excellent ampli qui fait très bien ce dont il est conçu pour, rien de superflux.
