FURUTECH HF-X-NCF HDMI 2.1 Cable 8K/60Hz 4K/120Hz 48Gbps HDCP2.3 eARC HDR10+ Silver Plated OFC Copper 5m
Furutech offers with the HF-X-NCF a high-end HDMI cable, compatible with 4K/8K 48Gbit/s and incorporating the know-how and attention to detail of the brand.
By buying this product you get 189 loyalty points
Reference : 15707
639,00 €tax incl.
532,50 € tax excl.
Shipping date: 07-04-2026.
Furutech HF-X-NCF
Furutech HF-X-NCF Câble HDMI 8K/60Hz 4K/120Hz 48Gbps HDCP2.3 eARC HDR10+ Cuivre OFC plaqué Argent 1.2m
The body of the connectors uses the brand's NCF (Nano Crystal Formula²) material, which eliminates electrical and mechanical vibrations, as well as noise derived from static electricity. This results in a particularly stable and clean transmission for incredibly accurate sound and a rich, vivid image. NCF is a crystalline material that has two "active" properties. First, it generates negative ions that eliminate noise. Second, it converts thermal energy into far infrared. Furutech combines this material with nano-sized ceramic particles and carbon powder, for their superior damping properties by piezoelectric effect. The resulting NCF material is the ultimate electrical and mechanical damping material. In addition, the connectors are α (Alpha) treated, the brand's cryogenic and demagnetization process, to promote stable and optimized transmission. The contacts benefit from a thick gold plating.
The cable itself is also optimized thanks to the use of very high quality materials. The conductors are made of silver plated and treated OFC copper α (Alpha), with a section of 26AWG. Each conductor is individually insulated with a high density polyethylene sheath. They are then grouped by two in the heart of an aluminum foil shielding preventing static electricity and EMI. Then comes a second shielding in double layer aluminum foil to block EMI, FFI and RFI, then a last shielding in braided copper and treated α (Alpha). The whole is finally covered with a flexible PVC sheath, having passed UL/CL3 flame resistance tests and conforming to the RoHS directive.
The HF-X-NCF supports high bandwidths of over 48Gbit/s and is compatible with 8K 60Hz and 4K 120Hz resolutions. It also supports HDCP 1.4/2.2/2.3, eARC/ARC, HDR10/HDR10+, VRR/60~240Hz, DSC, QMS, QFT and ALLM standards and technologies.
Product typeHDMI Cable
Length5m
ConductorsSilver plated µ-OFC Copper, α (Alpha) treatment
Conductors section0.129mm² (26AWG)
InsulationHigh density polyethylene
Triple shieldingAluminum foil
Double sided aluminum foil
Braided copper, α (Alpha) treatement
External sheathPVC UL/CL3 RoHS compliant
Connectorsα (Alpha) treatment
Contacts platingGold
Cable diameter8.5mm (±0.2mm)
Supported bandwidth> 48Gbps
Supported resolutions8K 60Hz 48Gbps
4K 120Hz 32.08Gbps
Standards and technologiesHDCP1.4/2.2/2.3
eARC/ARC
HDR10/HDR10+
VRR 60Hz~240Hz
DSC
QMS
QFT
ALLM
cOLORPurple
Length (m)5.0
ShieldingYes
Section (mm²)0.129
ConnectorHDMI
Furutech offers with the HF-X-NCF a high-end HDMI cable, compatible with 4K/8K 48Gbit/s and incorporating the know-how and attention to detail of...
