The Eltax SW800 active bass-reflex subwoofer features a 20cm-diameter driver. It's powered by a 60W integrated amplifier. This model is ideal for integration into a small or medium-sized HiFi or home theater system. It will deliver deeper, punchier bass for greater immersion in your music or films. The bass-reflex loading uses a port on the side of the subwoofer, providing deep bass.
The Eltax SW800 subwoofer features a frequency response from 40Hz to 150Hz. Its cutoff frequency can be adjusted within this range using the rotary knob on the rear of the unit. Phase can be set to 0° or 180° for maximum compatibility with your existing system. The SW800 subwoofer features a stereo RCA input and an LFE input. It can therefore be combined with a wide range of HiFi and home-cinema amplifiers.
Product type | Active subwoofer |
Load type | Bass Reflex |
Driver diameter | Ø20cm |
Frequency response | 40-150Hz |
Adjustable cut-off frequency | From 40Hz to 150Hz |
Power | 60W |
Connectivity | 1x Stereo RCA line input 1x LFE input |
Vent position | Lateral |
Dimensions (WxHxD) | 290 x 330 x 350mm |
Cabinet material | MDF |
Weight | 6.7kg |
Color | Black |
