DAYTON AUDIO OS-2S Speaker Stands with Spikes
The Dayton Audio OS-2S speaker stand offers a stable base with decoupling spikes. Thanks to 4 mounting points and sturdy spikes, each stabilizer is able to bear up to 90kg (200lbs) of load.
Reference : 19933
64,90 €tax incl.
54,08 € tax excl.
Last items in stock !
Shipping date: 20-05-2025.
Dayton Audio OS-2S Speaker Stands with Spikes
Dayton Audio OS-2S stand photo
The Dayton Audio OS-2S speaker stand offers a stable base with decoupling spikes. Thanks to 4 mounting points and sturdy spikes, each stabilizer is able to bear up to 90kg (200lbs) of load. The black steel mounting brackets are each approximately 30cm wide and 4mm thick. Each 3.81cm (1.5") spike is adjustable and features a locking nut to adapt the bracket to different environments. This stand is particularly suitable for column speakers, for example.
Dayton Audio OS-2S speaker stands highlights:
  • Heavy-duty, durable steel construction
  • Decoupling spikes for improved clarity, imaging and bass response
  • Ø30mm x 38mm adjustable decoupling spikes with locking nut
  • Even weight distribution with up to 90kg load per bracket
  • Compatible with speakers from 12.7cm to 21.59cm wide (5“ to 8-1/2” wide)
This product consists of two parts to support a single speaker or small subwoofer. If you wish to use it to support 2 speakers, it is necessary to order 2 units.
Dayton Audio OS-2S stands dimensions
Product typeSpeaker stands
MaterialSteel
Supported weight per bracket90kg
Decoupling spikes
DimensionsSupport: 4 x 40 x 300mm
Spikes : Ø30 x 38mm
Locknut: Ø30 x 20mm
Package1x Dayton Audio OS-2S Speaker Stands with Spikes
Diameter (mm)N/A
MaterialSteel
Height38.0
DAYTON AUDIO OS-2S Speaker Stands with Spikes Steel Black
The Dayton Audio OS-2S speaker stand offers a stable base with decoupling spikes. Thanks to 4 mounting points and sturdy spikes, each stabilizer is...
