Amplifier Board with Volume Control Bluetooth 5.0 TPA3116D2 2x75W 8 Ohm
This small amplifier module embeds two TPA3116D2 chips and is able to deliver up to 2x76W at 8Ω and 2x110W at 4Ω. Its output stage benefits from an LC filtering circuit, allowing a clean and precise sound reproduction. Practical, it also integrates a Bluetooth 5.0 reception chip, allowing you to broadcast your music remotely, from a smartphone for example.
3.8 / 5
Reference : 14684
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 02-09-2025.
amplifier module
Volume control Bluetooth 5.0 2x TPA3116D2 2x75W 8Ω
This small amplifier module embeds two TPA3116D2 chips and is able to deliver up to 2x76W at 8Ω and 2x110W at 4Ω. Its output stage benefits from an LC filtering circuit, allowing a clean and precise sound reproduction. Practical, it also integrates a Bluetooth 5.0 reception chip, allowing you to broadcast your music remotely, from a smartphone for example. A line input on 3.5mm jack is also available. Finally, the module also has a volume control.
Product typeAmplification module
Amplification typeClass D
Amplification chip2x TPA3116D2
Power12V Supply voltage : 2x24W @ 8Ω / 2x40W @ 4Ω
15V Supply voltage : 2x36W @ 8Ω / 2x60W @ 4Ω
19V Supply voltage : 2x64W @ 8Ω / 2x92W @ 4Ω
24V Supply voltage : 2x76W @ 8Ω / 2x110W @ 4Ω
InputsBluetooth
Jack 3.5mm
OutputsSpeaker terminal
LC Filter
Bluetooth version5.0
Bluetooth transmission distance15m
ProtectionsOvervoltage
Under voltage
Thermal control
DC Detection
Supply voltage range5 - 27V DC
Total dimensions100 x 53 x 16mm
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)75.0
4 reviews
Amplifier board
The product is as I expected.
This review has been posted for Amplifier Board with Volume Control Bluetooth 5.0 TPA3116D2 2x75W 8 Ohm
Surprenant
Alimenté en 24v 6A à découpage, il attaque une enceinte maison avec de très bons vieux HP voiture.
Il est petit et léger, mais il envoie du lourd !
Seul défaut, le cordon d'alim est vraiment fin, pas sur que la section du fil tiennent longtemps à plein puissance.
rectificatif de mon précedent avis il marche très bien
je rectifie mon précédent avis. En testant avec une alimentation 19V celle du type "Allo" à 18€ de chez audiophonics le module marche très très bien c'est excellente qualité meme tout rentre dans l'ordre plus de bruit.
Fuyer les alimentations PC avec prise de terre bon marché
le module vous donnera du bonheur avec une bonne alimentation 2P.
il faut le savoir
correct mais trop sensible a l'alimentation donc peu utilisable
ce petit ampli est sympathique marche correctement sauf sa sensibilité à alimentation utilisé avec 3 alimentations différentes de 12 à 19 volts certes à découpage venant de Pc portables.
il n'aime pas du tout il subsiste un bruit audible pendant l'écoute de la musique (pour info rien avec mes fx audio et smsl avec les memes alims) C'est présent en bluetooth rien sans musique car le silencieux se met en marche par contre sur l'entrée analogique le bruit est perceptible tout le temps dommage car il est bien agencé à essayer avec une alimentation linéaire sinon utilisable en ambiance lointaine seulement.
This small amplifier module embeds two TPA3116D2 chips and is able to deliver up to 2x76W at 8Ω and 2x110W at 4Ω. Its output stage benefits from an...
