Amplifier Board TDA7498E Bluetooth 5.0 WiFi AirPlay2 2x100W 4 Ohm
The CL-500A is a particularly complete and powerful Class D amplifier module. Based on a TDA7498E amplifier chip, it is capable of developing no less than 2x100W under 4 Ohm with a high efficiency, while offering a clear and dynamic restitution. With an extended connectivity, it will allow you to broadcast your music remotely via WiFi or Bluetooth 5.0 from any other connected device. There are also inputs for Ethernet (RJ45) for a wired network connection, a stereo RCA, Optical Toslink and a USB-A connector for connecting a storage device. On the output side, the CL-500A has a speaker output but also an RCA output and a Toslink Optical output. The module is also compatible with the DLNA and AirPlay2 transmission protocols. The CL-500A comes with an IR remote control that will allow you to control the playback from your sofa.
Product type | Amplifier board |
Amplification type | Class D |
Amplifier chip | TDA7498E |
Inputs | WiFi 2.4/5Ghz 1x Ethernet RJ45 Bluetooth 5.0 1x Stereo RCA 1x USB-A 1x Optical Toslink |
Outputs | Speaker terminals 1x Stereo RCA 1x Optical Toslink |
WiFi Protocols | IEEE 802.11 a/b/g/n/ac 1x1 dual band 2.4/5GHz |
Bluetooth version | 5.0, compatible EDR / BLE |
Frequency response | 20Hz - 20kHz |
Output power | 2x100W @ 4Ω |
THD+N | 0.05% |
SNR | 105dB |
Supported formats | MP3, AAC, FLAC, ALAC, WMA, APE, WAV, OGG |
Supported transmission protocols | AirPlay2, DLNA, QQ Music Qplay |
Dimensions | 107 x 136 x 29mm |
Supply voltage | 24VDC 6A / 28VDC 5A / 32VDC 5A (power supply not included) |
Weight | 184.5g |
Package | 1x Module CL-500A 1x IR Remote control |
Input | Optical |
Input | RJ45 |
Input | RCA |
Input | Bluetooth |
Input | WiFi |
Input | USB |
Output | Optical Toslink |
Output | Speaker terminal |
Output | RCA |
Channel | 2 (Stereo) |
Class | Class D / T |
Power (W) | 100.0 |
