Stereo Class T TA2022 2x90W 4Ω
This Class T stereo amplifier module is equipped with a Tripath TA2022 amplifier chip, allowing it to deliver 90W of power under 4Ω per channel. This substantial energy reserve combined with high efficiency allows it to be associated with a large number of speakers, including demanding models.
The entire module benefits from a high quality design including a KBJ1010 diode bridge, 2 Samyoung 3300µF 50V filter capacitors and a power circuit control using a L7805CV voltage regulator, in order to supply the entire circuit in a clean and stable way. This double-sided PCB also contains 4 Siemens 2.2µF coupling capacitors at the signal input and high precision resistors (+/-1% tolerance) to ensure a very good SNR.
On the connector side, the module simply offers a stereo input on XH 2.54mm 3 pins connector and an output to speakers on screw terminals. Finally, a 6mm notched shaft potentiometer controls the volume level.
It is essential to combine this module with a suitable heat sink (sold separately) in order to properly dissipate the heat released by the amplifier chip. A temperature too high to irreversibly damage the equipment.
Product type | Amplification module |
Amplification chip | Tripath TA2022 |
Amplification type | Class T |
Power | 2x90W @ 4Ω |
Input | 1x XH 2.54mm 3 pins connector |
Output | 1x Speaker screw terminals |
Total dimensions | 98.4 x 82 x 36.8mm |
Fixation holes spacing | 89 x 59mm |
Power supply | 22VAC - 0 - 22VAC |
Input | XH 2.54mm |
Output | Speaker terminal |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TA2022 |
Power (W) | 90.0 |
