File Reader with Class D Amplifier 5W Board UART / IO
This intelligent voice module embeds a sub-section I/O trigger, UART and ONE_LINE single bus serial port control. A 5W Class D amplifier circuit is integrated and can directly drive a 3~5W speaker at 4Ω. The module supports MP3 and WAV formats. Its Micro SD slot accepts cards up to 32GB. A Micro USB port allows you to simply power the contents of the Micro SD card.
Reference : 16422
6,90 €tax incl.
5,75 € tax excl.
File Reader Board
With Class D Amplifier 5W Board UART / IO
Module Vocal / Amplificateur Class D 5W / Lecteur de Fichiers
Product typeVoice module, amplifier and file reader
Supported file formatsMP3
WAV
Supported sampling rates8 / 11.025 / 12 / 16 / 22.05 / 24 / 32 / 44.1 / 48kHz
Amplification typeClass D
Output power5W @ 4Ω
Dynamic range90dB
SNR85dB
Supported file systemsFAT16/FAT32
Max Micro SD storage32Go
UART SupportUp to 65535 tracks
I/O SupportUp to 255 tracks
Single bus ONE_LINE support
Supply voltage5VDC
Operating temperature20~85°C
Dimensions40 x 40 x 9mm
InputMicro SD
OutputJack 3.5mm
OutputSolder pad
Channel2 (Stereo)
Amplifier chipN/A
Power (W)5.0
This intelligent voice module embeds a sub-section I/O trigger, UART and ONE_LINE single bus serial port control. A 5W Class D amplifier circuit is...
