By buying this product you get 56 loyalty points
Plate NCore Amplifier 2x250W DSP ADAU1450 DAC AK4454 192kHz
The Hypex FusionAMP FA252 amplifier will allow you to design a subwoofer or a two-way active speaker. It is based on two NCore modules capable of developing no less than 2x250W RMS. The two modules can also be bridged to form a 500W mono amplifier. This high power allows the FA252 to accompany loudspeakers that need a lot of energy to reveal their potential.
The FA252 offers a balanced analog input and output in XLR 3-pole format, an AES3 input and output, a coaxial SPDIF input and output, a Toslink optical SPDIF input and an unbalanced RCA Stereo input. The XLR and AES outputs are directly connected to the XLR input for one and AES for the other, and thus allow you to create a chain with several FusionAMPs, the maximum number of modules being limited by the capabilities of your source.
This FusionAMP FA252 integrates a DSP. A USB connector allows you to configure your amplifier via the software specially developed by Hypex. This software offers many possibilities to adapt your amplifier to your needs, like the creation of custom filters.
The front panel of the amplifier displays a series of 4 status LEDs. The first one warns of a malfunction or the reaching of a limit, so as not to degrade the equipment.
The next 3 LEDs, green, simply display the custom profile selected and therefore in use. To change the profile, simply press the Select button. If the amplifier is in mute mode, then the LED of the selected profile will blink slowly.
| 1 | Balanced analog input / output |
| 2 | Single-ended analog input |
| 3 | Mini-USB connector for configuration |
| 4 | Status LED |
| 5 | AES digital input / output |
| 6 | SPDIF Coaxial Input / Output |
| 7 | Toslink Optical Input |
Note: In order to protect your speakers, the DSP does not have a pre-configured crossover from the manufacturer. A crossover must therefore be set up and injected using the Hypex Filter Design (HFD) software for the FusionAMP to provide an output signal.
| Specifications | |
| Product type | Amplifier |
| Output power | 2x250W @ 4 Ohm / (Bridgeable to 1x400W) 2x200W @ 8 Ohm / (Bridgeable to 1x500W) 2x180W @ 8 Ohm |
| Inputs | 1x Balanced 3 poles XLR 1x AES 1x Single-ended stereo RCA 1x SPDIF Coaxial 1x Optical Toslink |
| Outputs | 1x 3 poles balanced XLR (direct ouput) 1x AES (direct output) 1x SPDIF Coaxial |
| DSP | ADAU1450 |
| DAC | AK4454 |
| ADC | AK5554 |
| SRC | SRC4382 - Max sampling rates : 192kHz |
| Frequency response | 10Hz - 50kHz |
| SNR | 121dB |
| THD+N | 0.0015% (10Hz-20kHz @ 0.5x rates power output) |
| General | |
| Dimensions | 315 x 135 x 55mm |
| Weight | 1kg |
| Color | Black |
| Package | 1x FusionAMP FA252 1x Speaker cables |
| A | 315mm |
| B | 135mm |
| C | 55mm |
| D | 291mm |
| E | 111mm |
| Input | Optical |
| Input | RCA |
| Input | SPDIF |
| Input | AES/EBU |
| Input | XLR |
| Output | XLR |
| Output | AES/EBU |
| Output | Coaxial SPDIF |
| Channel | 1 (Mono) |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | Hypex Ncore |
| Power (W) | 250.0 |
| Power (W) | 500.0 |
