LQSC Class AB Stereo Module Amplifier TDA7377 2x30W 4 Ohm
This low-cost yet highly efficient Class AB amplifier module is based on a TDA7377 chip allowing it to develop up to 2x30W under 4Ω. The quality components integrated in this module, such as Nichicon capacitors for filtering or gold-plated contacts, ensure a beautiful sound reproduction.
3.0 / 5
Reference : 13801
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 07-04-2026.
Amplifier module
Module Amplificateur Stéréo Class AB TDA7377 2x30W 4Ω
This low-cost yet highly efficient Class AB amplifier module is based on a TDA7377 chip allowing it to develop up to 2x30W under 4Ω. The quality components integrated in this module, such as Nichicon capacitors for filtering or gold-plated contacts, ensure a beautiful sound reproduction. At the input of this module is a 3.5mm jack connector as well as a 2.54mm 3 pin XH connector. At the output, the board simply offers screw terminals to connect to your speakers. The module also includes a rotary knob for volume control.
Product typeAmplifier module
ChannelsStereo (2)
Amplification chipTDA7377
Amplification typeClass AB
Power2x30W @ 4Ω
Inputs1x Stereo Jack 3.5mm
1x 3 pins XH 2.54mm connector
OutputsSpeaker screw terminals
Supply voltage9-18V DC
ProtectionsShort circuit
Over heat
Overcurrent
PCB dimensions58.7 x 55mm
Total dimensions90.6 x 55 x 26.7mm
Fixation holes spacing48 x 25.5mm
Package1x Amplifier module
1x 3 pins XH 2.54mm
InputXH 2.54mm
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTDA7377
Power (W)30.0
2 reviews
Vraiment excellent bravo fabrication ok
Sur du haut rendement (38 cm dans 105 litres, 97 dB/w + 21 cm + tweeter) le son est très détaillé sans être froid.
Mes enceintes DIY ont une impédance de 5 ohms mini vers 100 Hz.
Le grave ne peut bien sûr être comparé à celui délivré par un ampli puissant,
Il ne s'écroule toutefois pas quand il faut restituer les basses (vive le haut rendement)
Qualité de fabrication bonne sur mes deux exemplaires.
Ce qui est le plus apprécié, c'est la transparence et les timbres.
Soignez l'alimentation, elle est linéaire et DIY pour ma part.
Bravo indépendamment du prix !
Pour de la multi-amplification haut-rendement à partir de 100 Hz et si 'bas' rendement un peu plus haut. Merci
This review has been posted for LQSC Class AB Stereo Module Amplifier TDA7377 2x30W 4 Ohm
Soudure sèches - Potentiomètre grippé
J'ai reçu le produit avec des soudure défaillantes sur les condensateurs. Le potentiomètre était également non fluide, avec des points durs. A éviter.
This low-cost yet highly efficient Class AB amplifier module is based on a TDA7377 chip allowing it to develop up to 2x30W under 4Ω. The quality...
