MA-CX04 Amplifier Module Class D CxD500 500W mono
Reference : 8566
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 05-08-2025.
This Class D amplifier module based on the IRS2092S amplifier controller will deliver a powerful and robust sound and a good power reserve.
The CxD500 requires a differential supply voltage in the range of +/-62V to +/-86V for the power stage, a low power differential voltage of +/-18 to +/-28V 20-30mA for the input stage, and a separate voltage, referenced to V- with the value in the range of 16V to 25V at 40-50mA for the driver stage. The suitable power supply for a single module > 500W on 4R is the SMPS600RxE, also suitable for two modules delivering 300W on 8R.
If a Connex power supply recommended by the manufacturer is not used to power the module, then it will require three power supplies. In this case, it will require, in addition to the +/-VCC power supply, additional +AUX, -AUX and Vbias power supplies to be distributed on the AuxSupply connector.
See the CXD500 Module Datasheet
Features:/ Strong>
  • Dimensions: 100x40x35mm
  • Power: 500 W under 4 ohms
  • "Ploc" anti-ignition system
  • It is necessary to attach the Aluminum radiator to the housing to improve dissipation.
https://www.audiophonics.fr/images2/8237/8237_module_CxD500_1.png
InputNC
OutputPCB Connector
Channel1 (Mono)
Amplifier chipN/A
Power (W)500.0
