TINYSINE TSA3118B SMA Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks to its Class D architecture. The module also integrates a Bluetooth AudioB Plus receiver from the brand, supporting the aptX protocol which allows faster and more stable signal transmission.
Reference : 14142
40,90 €tax incl.
34,08 € tax excl.
TinySine TSA3118B SMA
TinySine 3118 Module Amplificateur TSA3118B Bluetooth aptX TWS SMA 2x50W
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good performance thanks to its Class D architecture. The module also integrates a Bluetooth AudioB Plus receiver from the brand, supporting the aptX and aptX Low Latency protocols that allow faster and more stable signal transmission. The TSA3118 can be used to accompany passive speakers with an impedance of 4 or 8 Ohm.
The module can also be used in TWS mode. The latter allows you to wirelessly pair several of these amplification modules and therefore enjoy a multi-channel system. The 3-pin audio output connector can also be used to connect a Subwoofer amplifier module. The BVC port allows it to connect a volume control module such as the TinySine TSA1000 or TinySine TSA1020. Finally, this version of the module integrates an SMA connector on the Bluetooth receiver to connect the supplied antenna and thus increase the Bluetooth transmission distance.
The amplifier automatically detects the AUX and line inputs as well as Bluetooth, the latter having a higher priority. When the Bluetooth source is disconnected or paused, the amplifier automatically switches to the AUX / Line input.
The combination of the TSA3118 and TSA1000 allows you to control the volume level via the BVC port, whether for RCA or Bluetooth input.
Several TSA3118 modules can be connected together to create a multi-channel amplification system. The audio output connector can also be connected to an amplifier module for subwoofer.
2 modules operating in TWS mode.
It is necessary to remove the jumper activating the Auxiliary input of the slave module before pairing to TWS.
xxx
  • S1 : Press 3s to enter pairing mode. Press 6s to reset the pairing information.
  • S1 + S2 : Press 1s to enable TWS slave mode.
  • S1 + S3 : Press 1s to enable TWS master mode.
  • S2 + S3 : Press 1s to disable TWS connection.
Product typeAmplifier module TPA3116D2
Amplification ClassD
InputsBluetooth
1x Line input on PH2.0 3 pins connector
OutputsSpeaker terminals
1x Stereo RCA
1x Line output on PH2.0 3 pins connector
Other connectors1x BVC port for control panel on PH2.0 5 pins connector
Bluetooth version4.2
Supported Bluetooth codecsaptX, aptX Low Latency
AAC
SBC
TWS support
Codecs Bluetooth supportésaptX, aptX Low Latency
AAC
SBC
ProtectionsOver voltage, Under voltage
Overload
Thermal protection
Measurements
ParameterConditionMin.Typ.Max.
Supply voltage-10V DC21V DC24V DC
Max current100W @ 4Ω-5.29A-
Efficiency50W @ 4Ω87%-92%
Minimum load impedance-3.2Ω--
Switching frequencySD Floating-394kHz-
Gain-24dB25dB26dB
Input sensitivity (RMS)@ 4Ω, 50W, 1kHz-808mV-
Input impedance--22kΩ-
Output power@ 4Ω THD+N 1%-36W-
@ 4Ω THD+N 10%-50W-
Frequency response@ +/-3dB, 4Ω20Hz-20kHz
THD@ 4Ω, 1W, 1kHz-0.0299%-
@ 4Ω, 10W, 1kHz-0.073%-
Dimensions9 x 103 x 20mm
Fixation holes spacing86.5 x 60mm
Package1x TinySine TSA3118B board
1x Bluetooth antenna
InputPH 2.0mm
OutputSpeaker terminal
OutputPH 2.0mm
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)50.0
Petit mais costaud!
J'en possède 2 pour utilisation différentes et j'ai fais plusieurs test avec des systemes stéréo très différents. Ce petit ampli est difficile a mettre en défaut.
Klipsch r41m, parfait.
Focal SIB, parfait.
Focal aria 905, parfait.
Focal opal 8ti, parfait.
En gros il ira parfaitement avec n'importe quelle enceinte de type bibliothèque.
Maintenant on passe aux colonnes.
Klipsch r28-f, la encore parfait! Sur ces colonnes a au rendement (98db), il fait le même boulot que mon Denon x3700h.
Cabasse baltic Evo, la encore extrêmement surpris du résultat sur ces colonnes haut de gamme, le rendu est au moins identique a des ampli de plusieurs milliers d'euros qui doivent habituellement ces colonnes!
Le dernier essai et le seul décevant à été effectué sur des Focal chorus 826V W, modèle particulier comportant des membranes très rigides de la gamme electra, difficiles a driver pour ce petit ampli, mais ne lui n'en voulons pas.
Aucun des ces test n'a fait chauffer l'ampli, il reste quasiment a température ambiante en permanence.
J'ai monté mes 2 amplis dans des boîtes aluminium, l'un alimenté sur secteur par une alim 24v achetée ici, et l'autre avec une batterie de ma confection 21v 5000mah, je suis extrêmement ravis de ces petites bestioles! Le son est précis et toute la dynamique de vos enceintes sera mis en valeur.
Son rapport prix/performances est imbattable!
This review has been posted for TINYSINE TSA3118B SMA Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks...
