TINYSINE TSA7800B Class D 2.1 Amplifier Board TPA3116D2 DSP Bluetooth aptX 2x50W + 1x100W
The TinySine TSA7800B module is a 2.1 Class D amplifier, capable of delivering a power of 2x50W + 1x100W. It also embeds a Bluetooth 5.0 AudioB receiver, supporting the high quality aptX transmission codec. In short, the TSA7800B is a combined card integrating an amplifier, a DAC and a DSP.
Reference : 16026
79,00 €tax incl.
65,83 € tax excl.
TinySine TSA7800B
TinySine TSA7800B Module amplificateur 2.1 Class D TPA3116D2 DSP Bluetooth aptX 2x50W 1x100W
The TinySine TSA7800B module is a 2.1 Class D amplifier, capable of delivering a power of 2x50W + 1x100W. It also embeds a Bluetooth 5.0 AudioB receiver, supporting the high quality aptX transmission codec. In short, the TSA7800B is a combined card integrating an amplifier, a DAC and a DSP. Its amplifier stage is based on a pair of TPA3116D2 chips. It can be used with any 4Ω or 8Ω speaker (the subwoofer channel can accompany a 2Ω speaker).
The onboard DSP is an ADAU1701. It allows to adjust the parameters of each channel separately. Moreover, the module is TWS compatible, so several of them can be coupled to extend the audio system.
External control panel connector
The module includes three buttons to control the volume level and the current playback. It is however possible to connect a more complete external control module.
Pinout :
  • P/P : Play/Pause button
  • VOL+ : Volume + and fast forward
  • VOL- : Volume - and fast rewind
  • 1.8V
AUX connector
The default DSp program mixes the RCA and Bluetooth audio signals and sends them to the amplifier. If you want to manually select the RCA or Bluetooth input, you can connect an external switch to this port and load a different DSP program.
Volume potentiometer connector
It is possible to connect a 10k potentiometer to the TSA7800B module to take advantage of a volume control.
DSP programmer connector
The TSA7800B integrates a DSP, it is possible to modify its settings. To do this, it is necessary to use the USBi JTAG Sigma DSP programmer (sold separately).
The basic DSP program integrated with the module mixes RCA and Bluetooth audio streams and sends them to the speakers. The DSP setting offers the possibility to select the audio source via an external switch.
TWS Mode
Several TSA7800B modules can be wirelessly connected to each other using the TWS mode. The buttons below give access to the TWS functions.
  • S1 - Long press 3s : Activate pairing mode
  • S1 - Long press 6s : Delete pairing information
  • S1+S2 - Long press1s : Activate TWS slave mode
  • S1+S3 - Long press 1s : Activate TWS master mode
  • S2+S3 - Long press 1s : Disconnecting the TWS mode
Product typeAmplifier board
Number of channels2.1
InputsBluetooth 5.0
1x Stereo RCA
OutputsScrew terminals
Supported Bluetooth codecsAAC, SBC, aptX, aptX Low Latency
Puissance2x 50W @ 4Ω, THD+N 10%, 21V
2x 30W @ 8Ω, THD+N 10%, 24V
2x 18W @ 4Ω, THD+N 10%, 12V
Canal 100W : 1x100W @ 2Ω, THD+N 1%, 24V
THD+N0.03% @ 4Ω, 1W, 1kHz, 21V
Frequency response20Hz-20kHz (±3dB)
Input impedance22kΩ
Minimum load impedance3.2Ω
Gain18dB
24dB
34dB
Efficiency87% @ 50W, 4Ω, 12V
92% @ 50W, 4Ω, 24V
I2S Sampling rate48kHz
ProtectionsOver/Under voltage
Overloads
Thermal protection
Supply voltage12-24VDC
Dimensions135 x 92 x 34mm
OutputSpeaker terminal
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipTPA3116D2
Power (W)50.0
Power (W)100.0
Lieferung und Ablauf
Audiophonics ist ein Top Lieferant mit einem klasse Service und Kundenservice.
Hervorragende Preise und schnelle Lieferung.
Kann man nue empfehlen.
This review has been posted for TINYSINE TSA7800B Class D 2.1 Amplifier Board TPA3116D2 DSP Bluetooth aptX 2x50W + 1x100W
The TinySine TSA7800B module is a 2.1 Class D amplifier, capable of delivering a power of 2x50W + 1x100W. It also embeds a Bluetooth 5.0 AudioB...
