WONDOM JAB3+ AA-JA31213 Class D Amplifier Board Bluetooth 5.0 DSP ADAU1701 1x60W 4 Ohm
The Wondom JAB3+ is an amplifier module capable of developing a power of 1x60W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio solution. Thanks to the latter, the JAB3+ can be programmed with SigmaStudio and AppControl via an intuitive graphical interface.
Reference : 16521
43,90 €tax incl.
36,58 € tax excl.
Shipping date: 18-07-2025.
Wondom JAB3+
Wondom JAB3+ AA-JA31213 Module Amplificateur Class D Bluetooth 5.0 DSP ADAU1701 1x60W 4 Ohm
The Wondom JAB3+ is an amplifier module capable of developing a power of 1x60W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio solution. Thanks to the latter, the JAB3+ can be programmed with SigmaStudio and AppControl via an intuitive graphical interface (requires the use of a Wondom ICP5 module, not supplied).
In addition to its speaker output, the JAB3+ has an additional mixed audio output that can be used with another amplifier module to create a 2.1 or 4.0 system. The PC interface then allows the amplifier to be configured in mono or stereo mode. In addition, the JAB3+ can be battery-powered to create a portable, high-performance audio system.
Bluetooth 5.0
The JAB3+ uses a Bluetooth 5.0 module as input, supporting AAC, SBC, aptX, aptX LL and aptX HD codecs and enjoying a high reception sensitivity of up to 9dB and -90dBm. This makes it possible to pair the JAB3+ with an audio source. An external antenna port is also available in case the JAB3+ is installed in a box.
DSP ADAU1701
The JAB3+ therefore embeds an ADAU1701 DSP chip for audio signal processing. Four ports allow to mount external potentiometers (sold separately). These will allow you to control volume, gain, bass and treble levels. When used with a Wondom ICP5 module (sold separately), you can adjust many audio parameters via the SigmaStudio software or a control application.
Line input
In addition to the Bluetooth input, the JAB3+ offers a line input. The signal from both inputs can be mixed before being transmitted to the amplifier circuit.
Wondom JAB3+ Module Amplificateur Class D Bluetooth 5.0 DSP ADAU1701 1x60W 4 Ohm
Product typeAmplifier module
Number of channels1
Output power1x60W
PBTL Compatibility
InputsBluetooth 5.0
Line input
Outputs1x Speaker output
1x Line output
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD
Measurements
ParameterConditionsMin.Typ.Max.
Min. load impedance-5.6Ω8Ω-
Efficiency1x60W @ 4Ω, 1kHz-88%
Amplifier gain@ 4Ω, 20Hz-20kHz-25.8dB-
Input sensitivity1x60W @ 4Ω, 1kHz, 23.5dB-770mV-
HFP Cutout frequency-0.25kHz-2kHz
LFP Cutout frequency--20kHz-
SNR1x60W @ 4Ω, THD+N=1%, 25.8dB, A-Weighting-91dB-
THD+N10W @ 4Ω, 1kHz, 25.8dB-0.039%-
Input impedance--10kΩ-
Output noise levelA-Weighting, input connected to GND, 25.8dB-163µV-
DC Offeset--10mV-
Crosstalk separation20Hz-20kHz, Gain = 26dB--60dB-
Alimentation12-26V DC (power supply sold separately) or via battery pack (sold separately)
Dimensions91.44 x 68.58mm
InputJack 3.5mm
OutputSpeaker terminal
OutputPH 2.0mm
Channel1 (Mono)
Amplifier chipN/A
Power (W)60.0
The Wondom JAB3+ is an amplifier module capable of developing a power of 1x60W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP...
