It was a gamble. Buy a more expensive clock or a cheaper? Didn't now what to expect. My first external clock. XC1 deliver! Using it with Gustard R26. The overall sound is calmer and quiter background.
Master Clock OCXO 10MHz Black
The Aune XC1 is an external master clock, using a high quality OCXO and featuring four isolated outputs, capable of operating simultaneously. Its ability to provide an extremely accurate and stable clock signal will allow you to increase the performance of your entire HiFi system.
Regarding the design of the XC1, in addition to its OCXO, it integrates only high quality components, including Panasonic and Sanyo capacitors or a power supply with very low noise and multi-level noise reduction.
1 | Display |
2 | ON/OFF switch |
3 | 9VDC Power supply |
4 | Sine wave 10MHz output |
5 | Sine wave 10MHz output |
6 | Square wave 10MHz output |
7 | Square wave 10MHz output |
Product type | Master clock |
Oscillator | OCXO |
Output frequency | 4x 10MHz |
Output power | > 7dBm (50Ω) |
Output waveform | 2x Square wave 2x Sine wave |
Rise time | < 2.75ns |
Audio stability | < 10ppt |
Frequency accuracy | < 1ppm |
Warm-up time | Basic warm-up : 5min Full warm-up : 60min |
Supply voltage | 9VDC 1A |
Dimensions | 145 x 171 x 45mm |
Color | Black |
Package | 1x Aune XC1 1x Power cable |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jan S.
