Closed-back Dynamic Wireless Headphones Ø40mm 32Ω 105dB 5Hz-32kHz
The ATH-S220BT from Audio-Technica is a dynamic, closed-back wireless headphone that offers clear sound reproduction, 60 hours of battery life and multi-point connectivity. Lightweight and adjustable, the ATH-S220BT is designed for maximum comfort, allowing it to accompany you during long listening sessions.
With a 40mm diameter transducer, the ATH-S220BT delivers dynamic, musical and accurate sound and is as effective for listening to music as it is for immersing yourself in your favorite movies.
Practical, the headphone can work in wireless mode thanks to the integration of a Bluetooth 5.0 receiver, allowing you to broadcast your music from a smartphone or a tablet for example. It also allows a multipoint pairing to connect your headphone simultaneously to several devices.
Running on battery, it also offers a consistent autonomy of 60 hours, complemented by the support of fast charging, 10 minutes of charging then guaranteeing 3.5 hours of listening. It also features a microphone and control buttons for easy call answering and music playback. The ATH-S220BT headphones also come with a 1.2m cable that includes a microphone and remote control for wired listening.
Product type | Headphone |
Headphone type | Dynamic Closed-back Wireless |
Transducers diameter | Ø40mm |
Frequency response | 5Hz - 32kHz |
Sensitivity | 105dB/mW |
Impedance | 32Ω |
Battery | LiPo 3.7V DC |
Battery life | ~ 60h (playback) |
Charging time | ~ 4h |
Integrated microphone | |
Microphone type | Electret capacitor |
Microphone sensitivity | -42dB (1V/Pa @ 1kHz) |
Frequency response of the microphone | 50Hz - 4kHz |
Microphone directivity curve | Omnidirectional |
Bluetooth version | 5.0 |
Max reception distance | 10m |
Weight (without cable) | 180g |
Color | Black |
Package | 1* Audio-Technica ATH-S220BT 1* USB charging cable 30cm 1* USB-A to USB-C cable with integrated microphone and remotre control 1.2m 1* Jack 3.5mm adapter |
Color | Black |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | 105.0 |
Lowest frequency (Hz) | 5 |
Highest frequency (Hz) | 32000 |
Wireless | Yes |
Cable termination | Wireless |
Headphone / Earphone connector | Wireless (Bluetooth) |
Headphone / Earphone connector | Jack 3.5mm |
