Neutral, transparent, never harsh sound.
Very solid and robust aluminum design but yet comfortable.
I'm using these as reference headphones in my system.
Highly recommended.
By buying this product you get 30 loyalty points
Aune's AR5000 are open-back headphones with a dynamic MLD ("Multi-Layer Distributed") driver of no less than Ø50mm. Thanks to its innovative driver, high-tilt acoustic structure and concentric-circle port system, these headphones deliver rich, detailed reproduction over a wide soundstage. They deliver deep, powerful bass for immersive sound, as well as a high level of comfort for long listening sessions. Aesthetically too, Aune has got it right, with champagne gold plating and meticulous finishes such as CNC-machined curves. A detachable 2x jack 3.5mm to jack 3.5mm termination cable is supplied with the Aune AR5000. Here are the various highlights of the Aune AR5000 headphones:
The Aune AR5000's dynamic driver delivers a sound reproduction of high purity and stability. In fact, its Ø50mm MLD diaphragm offers a balance between rigidity and damping that significantly reduces distortion across the entire frequency response range. The result is transparency and a high level of detail.
The acoustic structure of the Aune AR5000 features suspensions that improve airflow and thus the linearity of diaphragm movement, equalizing internal pressure. The result is a smooth, dynamic performance with deep, powerful bass.
These circum-aural headphones feature a concentric circle adjustment system and a very lightweight structure for comfort even during very long listening sessions. The foams are made of breathable material with a slow acoustic rebound.
"The AR5000 starts with looks that rival and beat headphones in multi-thousand dollar price range. Out of box tonality lacks some bass and treble which is easily remedied with equalization. Once there, combine with its very high sensitivity, you have a delightful headphone to listen to."
Product type | Open-back headphones |
Driver type | Dynamic with MLD technology |
Frequency response | 5Hz-41kHz |
Nominal impedance | 28 Ohm |
Sensitivity | 108dB (@ 1kHz, 1Vrms) |
THD | <0.03% (@ 1kHz, 100dB SPL) |
Cable type | Detachable |
Heaphone connectors | 2x Jack 3.5mm |
Cable terminaison | Jack 3.5mm |
Cable length | 1.5m |
Dimensions | 195 x 220 x 115mm (LxHxP) |
Net weight | 350g |
Package | 1x Aune AR5000 headphones 1x Cable 2x jack 3.5mm stereo to termination jack 3.5mm stereo |
Color | Champagne |
Impedance (Ω) | 28 |
Efficiency / Sensitivity (dB) | 108 |
Lowest frequency (Hz) | 5 |
Highest frequency (Hz) | 41800 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | Jack 3.5mm |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Robert C.
Anton P.
