HIFIMAN ANANDA Stealth Audiophile Planar Magnetic Headphone High Senstivity 93dB
Hifiman’s Ananda audiophile headphones are the result of many years of development. It is a lightweight model for unequalled comfort and equipped with ultra-thin Planar Magnetic membranes offering high sensitivity and impressive dynamics.
4.5 / 5
By buying this product you get 38 loyalty points
Reference : 13382
389,00 €tax incl.
324,17 € tax excl.
Hifiman Ananda
Pangea Record Doctor V Machine de nettoyage pour disque vinyle
Hifiman’s Ananda audiophile headphones are the result of many years of development. It is a lightweight model for unequalled comfort and equipped with ultra-thin Planar Magnetic membranes offering high sensitivity and impressive dynamics. In addition, Hifiman has ingeniously upgraded its production processes to create its new planar magnetic membranes at a lower price. Thus the brand sets a new performance/price ratio that will be difficult to exceed.
High sensitivity
The design of this headset allows it to stand out thanks to a high sensitivity of 103dB. It is thus able to be associated with any smartphone or portable DAP (personal music player), while ensuring low distortion and a rich and accurate sound reproduction.
Casque Audiophile Planar Magnetic Haute Sensibilité 103dB
Neo "supernano" Diaphragm (NsD)
The new NsD membranes of this Ananda are 80% thinner than those of the brand's previous helmets. The result is a faster and more detailed response while offering a musicality that was previously unattainable. With a thickness of 1 to 2 microns, NsD membranes
Planar Magnetic technology
Headphone speakers can use several technologies: Dynamic, electrostatic or even Planar Magnetic here. The latter consists of a very thin membrane with very thin electrical conductors. Two powerful magnets surround this membrane generating a magnetic field that places the membrane in suspension. Once powered by an electrical signal, a new magnetic field is generated by the passage of current through the membrane conductors. The latter magnetic field interacts with the permanent magnetic field of the magnets to move the entire membrane. This technology allows a much better reactivity, a wider frequency response and extremely low distortion.
Anti-reflexion grill
The Hifiman Ananda is equipped with grids to reduce sound reflection and provide greater clarity.
Insérer texte alternatif ici
Asymmetrical ear cups
The Ananda's ear cups use an asymmetrical design. This one has been specially designed by Hifiman to follow the curves of the ears and thus provide an essential comfort throughout your listening sessions.
Comfortable headband
With the same comfort in mind, the Ananda also offers an intelligent headband design that distributes weight. This way, you will feel no pain after long hours of listening and can simply enjoy your musical journey.
Robust connectors
The Ananda features brand new 3.5mm jack connectors. These are the most robust models created by the brand to date. This ensures high durability. You can also use any 3.5mm jack cable with this headset.
The Hifiman Ananda is the perfect companion for all portable devices, allowing them to develop excellent sound reproduction for high quality listening in any location.
Product typeHeadphone
Diaphragm typePlanar Magnetic
Frequency response8Hz - 55kHz
Sensitivity93dB
Impedance16 Ohm
Weight399g
Impedance (Ω)16
Efficiency / Sensitivity (dB)93.0
Lowest frequency (Hz)8
Highest frequency (Hz)55000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
2 reviews
un casque qui tient ses promesses
effectivement la on change de catégorie, de budget également...que dire du son, sinon qu'il est exceptionnel en tout point ?
la spatialisation est bluffante.
sur certain points la fabrication, de l'arceau par ex, peut laisser perplexe, néanmoins le confort est parfait.
seul reproche, a ce prix pas d'étui de protection, et surtout pas de cordon en 3m alors que ce casque est destiné a mon avis plutôt a l'utilisation domestique, même si le cordon fourni en 1,5m est pratique pour l'écoute d 'un baladeur.
l'écoute sur un FIIO M11 est d'ailleurs concluante, ce qui est loin d'être le cas pour bon nombre de casque que les baladeurs sont sensés alimenter sans problème (d'après les fabricants...) ceux qui ont du testés plusieurs modèles de différentes marques pour trouver le bonheur savent de quoi je parle.
par rapport aux chiffres avancées la puissance demandée est conséquente, par ex 2/3 pour le M11, je dirais de même sur un ampli.
je recommande chaudement ce casque, c'est vrai qu'il faut franchir le cap du budget, j'ai pour ma part attendu de nombreuses années...
aucun regret sur ce choix, les son est exceptionnel, c'est bien ce que l'on recherche.
This review has been posted for HIFIMAN ANANDA Stealth Audiophile Planar Magnetic Headphone High Senstivity 93dB
Clarté et polyvalence
Ce casque est assez imposant: oreillettes ovoïdes de 13 X 10 cm, 400 gr, arceau confortable. Le câble de +/- 1,30 m demandera une allonge pour se connecter à un ampli, mais est parfait pour se lier à un baladeur. La sensibilité de ce casque permet effectivement de le connecter sans problème à un (bon) baladeur, voire un smartphone.J'ai testé de nombreux genres: l'électronique de Bad guy (B Eilish), le sax de One Fine Day (J Harbeck 4tet), la trompette de Melody Nelson (D Zimmermann), le clavecin et le violon des Frères Francoeur (T. Langlois-J Taylor), la voix de Juste qq'un de bien (Enzo Enzo), l'orchestre symphonique du Concerto n° 2 de F Liszt (N. Arghamanyan), le tout avec bonheur. Le son est clair, ciselé. Sur certaines plages, les instruments se répartissent bien transversalement, mais également sur des plans différents, on se rapproche de l'écoute de SACD en 5.1. Les percussions de gros tambours sont bien rendues, les vibrations se limitant fatalement aux tympans. Le système ouvert, outre ses caractéristiques acoustiques, permet un port confortable, sans trop d'échauffement.
Hifiman’s Ananda audiophile headphones are the result of many years of development. It is a lightweight model for unequalled comfort and...
